Coolant leaking from IM
Old 10-13-2014
Hayden_Fourroux's Avatar
Hayden_Fourroux is an unknown quantity at this point
I just replaced the head gasket on my D16y8 and i was putting coolant in and i noticed coolant is leaking where the intake mani meets up with the block. It is leaking on the nut under the vtec solinoid. IM gasket is brand new. All the nuts on the mani are tightened to torque.
Hayden_Fourroux is offline
Old 10-13-2014
Re: Coolant leaking from IM
I sure can't see yours, but I know there are water passages between the head and intake manifold very near there.
Leftover gasket material that didn't get thoroughly scraped off?
ezone is offline
Old 10-14-2014
Went back and took the IM off and there was a small piece of leftover gasket. Thanks
Old 10-14-2014
Update: I cleaned the surface and the 1st leak is gone but not there is a new one. I spent about 3 hours trying to find it. From what i can tell it is coming from that black box that the PCV hose goes into. Right above the oil filter. Has anyone ever had this problem? I'm so lost
Old 10-14-2014
Um, the PCV oil separator can't leak coolant, but there are a lot of places the intake can leak, along with all the water hoses attached to it.
A NEW leak after pulling the intake? Inspect more closely. You didn't poke a hole in the pump feed tube, did you (or rust through)? You may need to pull the intake again.
ezone is offline
cukaracha
30
07-26-2015 12:01 PM
Bounddyy
07-08-2015 11:22 AM
ZILLA
07-05-2015 05:24 PM
Causemo
07-05-2015 06:42 AM
Causemo
07-04-2015 07:11 AM
Quick Reply: Coolant leaking from IM
