Gauge cluster question!
Old Sep 17, 2014
ewells90's Avatar
ewells90 is an unknown quantity at this point
I have a bone stock 2000 honda civic dx. (manual transmission) The gauge cluster does not have a tachometer (RPMS)
Is it true that I can take a 6th gen EX (vtec?) gauge cluster and directly swap them out without any wiring? does it mater if its auto or manual?
I was unable to find the answer to this question and I do not want to install an aftermarket tachometer (they look "tacky")
** if this is true is there anyone that wants to sell me a EX gauge cluster? I have paypal ready.
Old Sep 20, 2014
HerpDerp1919's Avatar
HerpDerp1919 is an unknown quantity at this point
Re: Gauge cluster question!
What I did was look at peoples guage installs or removals to get an idea of what wires needed to be present and pulled my dash out to see. But from my understanding it should work. Yours is still a 6th gen in 2000. I also read somewhere that when you pull the dash out, if the wire you need isnt there, its taped up farther back in the dash. My new guage cluster is on its way!
EDIT* As I looked in to it. there is a small difference in the auto and manual guages. The auto has the indicator of what gear youre in on one of the gauge pods. So before you buy check that. I have no idea if one out of a V-tec would cause problems. Missed that the first time i read through it
Old Sep 25, 2014
TRebel0EJ7's Avatar
99 Civic Coupe HX
TRebel0EJ7 is an unknown quantity at this point
I believe it should fit no problem just make sure to get a manual trans cluster and as for an extra plug or so I've also heard that it could be taped up away out of sight just peek around
Old Oct 1, 2014
Phatmatt's Avatar
Phatmatt is an unknown quantity at this point
They are all plug and play 96-00
I had no tach in mine, went to the junkyard and got a cluster with rpm.
Old Oct 15, 2014
civicbeast1999's Avatar
civicbeast1999 is an unknown quantity at this point
There is only one different wire clip if you put an automatic in a manual there will be an orange clip that's is just for the lights to let you know your in gear. Don't worry about installing that everything else just clips right in
fatih717171
Jul 25, 2016 06:22 PM
Kyles24
Jul 16, 2015 10:14 PM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
fatih717171
Jul 8, 2015 12:14 AM
