Power locks don't work
Rep Power: 0 Power locks don't work
I don't know anything about cars and I am hoping this is a simple fix that I can do it myself.
2005 Honda Civic EX Sedan.
- Driver door locks work w/keyless entry(it locks and unlocks)
- Remaining three doors (passenger door, the two read side doors) do not respond to the keyless entry (does not lock or unlock)
What could be the problem??
Where do I start?
I don't want my kids to freeze while waiting for me to open the doors.
Please help!
Where do I start?
Please help!
Rep Power: 125 Re: Power locks don't work
I have had to replace all my actuators on my 2005 CR-V twice. First time was with $10-$15 China pars on ebay that looked just like original but only lasted about a year.
When the drivers door power lock went, it did not quite move far enough and it somehow did affect the other since it is a little different with wires going to both connectors. The others have two connections but usual one is blank.
This is just for a picture...Get OEM from a dealer on line if they are your problem.
http://www.ebay.com/itm/New-Power-Do...5SnpXr&vxp=mtr
Rep Power: 0 Re: Power locks don't work
I have tried sitting inside opening/closing the doors with my keyless, only the driver door responds.
My door ont he driver side will unlock but wont lock now .....
Other than the driver door, none of my doros will respond to my keyless when i press the unlock unbutton. I have to manually open each door other than the driver door.
Is there any other way finding out if i have to replace all actuators?
Received 1,129 Likes
Rep Power: 191 Re: Power locks don't work
yep by actually taking stuff apart and testing it, check for power and ground coming to the actuator from the connector, ohm test the actuator as well. I had to replace 3 of the actuators on my last 05.
This is exactly what is happening. The power lock does not quite move far enough to fully unlock but still unlocks the door. Only the door on the driver side responds when i press the unlock button. The other three remains locks and i have to manually lock/unlock them.
Where do I start?
Please help!
Where do I start?
Please help!
Did you ever get an answer on this? I have the same problem. How did you go about fixing it?
Super Moderator
Received 1,860 Likes
Rep Power: 196 Re: Power locks don't work
Are you hitting the unlock button multiple times? Pressing it once only unlocks the driver door.
c4ldrew
10-06-2017 11:44 AM
mister2
01-03-2010 04:49 PM
silverEXcoupeWM
01-29-2003 12:00 AM
