Steering wheel shakes when turning
Rep Power: 0 Steering wheel shakes when turning
okay so this is kind of been an ongoing problem with my car for about a year but I kind of just ignored it but I thought since I'm a member of a Civic Forum I should ask people on here to see if they have had the same problem. and this could even be related to my alignment question that I posted but I doubt it.so when I'm driving on the freeway or even on normal road my steering wheel doesn't shake but if I tilt it to the left or to the right it shakes.and it only does it when I turn to the left or to the right?
Re: Steering wheel shakes when turning
Just for giggles, rotate the tires (front to rear) and see if that changes anything.
Received 1,443 Likes
Rep Power: 338 Re: Steering wheel shakes when turning
Rep Power: 0 Re: Steering wheel shakes when turning
Its weird if my front end is jacked up( tires not touching the ground) and i turn my steering wheel from left to right.. Smooth as can be. But when im driving freeway or normal road it does the shaking only when im turning my wheel from left to right
go to alignment shop and have them check it underneath for suspension parts (who knows, some of yer bushings might be goners, or even ball joint - could get ugly, go there, don't stay playing in the internet) Also, have them look the power steering.
Instead of telling them what parts to check, how about you take the mechanic for a ride to demonstrate what it is doing. THEN let them figure out why.
Hopefully you go to someone that can solve problems instead of throwing parts at it til you go away.
Well it has brand new ball joints, bushings, struts. I know cause i replaced those when i bought the car. I just had an alignment done about a week ago. But i will take it in again and have the mechanic ride with me. Iv even shaken the tires down( 12 & 6) and (9 & 3) just to see if there was play in that area. No play at all. And i know its not an unbalanced tire cause again my steering wheel only shakes when tilting/turning. When i hold it without turning or tilting its smooth as can be( THIS IS WHEN IM DRIVING). So we can rule out things here. (BALL JOINTS,BUSHINGS,STRUTS,UNBALANCED TIRE). thanks guys for all your input.
Well it has brand new ball joints, bushings, struts. I know cause i replaced those when i bought the car. I just had an alignment done about a week ago. But i will take it in again and have the mechanic ride with me. Iv even shaken the tires down( 12 & 6) and (9 & 3) just to see if there was play in that area. No play at all. And i know its not an unbalanced tire cause again my steering wheel only shakes when tilting/turning. When i hold it without turning or tilting its smooth as can be( THIS IS WHEN IM DRIVING). So we can rule out things here.(BALLJOINTS,BUSHINGS,STRUTS,UNBALANCED TIRE).
did you ever find out what was the problem? I am having the same issue on my civic 99 changed everything and it still shakes only while turning.
conspiracy90
06-07-2023 01:01 PM
anddrrey
05-11-2015 02:30 PM
edgenet
05-02-2015 08:00 PM
