02 EX - basic maint to creating a steady base for later modding?
Rep Power: 0 02 EX - basic maint to creating a steady base for later modding?
First time poster on this forum so if this is in the wrong section please let me know!
A few days ago I bought my second car, a 2002 5 speed civic coupe ex.
The car has 199xxx miles on it but so far its been running like a champ. The interior is extremely clean and I believe that an older lady owned the car prior to me. Ive found the breaks are wearing out (which I believe to be from the high mileage, but I could be wrong). And Im pretty sure there is a small oil leak somewhere. The oil pan was wet but there has been no oil leaking onto the ground at all. There are a few small spots of oil aswell around the engine block I believe.
I want to upgrade this car and mod it, and I already have a pretty decent list starting. But first before I start really getting into the car I wanted to do an overall tune up basically, but I dont know where to start. I changed the oil on the car yesterday. Should I replace the spark plugs? Other fluids? etc. etc. What can I do to make sure I have a steady basis for modding my car.
Here I have a brief list of things that I plan on doing in the future, just so you guys can see from the list, what I should inspect, or fix so that I dont have too big of problems later on that may occur from what I plan to be installing.
Cat-back exhaust
Air intake(SRI)
Coilovers - or a Lowering kit possibly
head and tail lights - HIDs?
front, rear, side skirts/lip
Rims/Tires
I have almost all the general tools I need to do all this to my car, jack, jack stands, etc. Ive been trying to research a lot on an exhaust. and I think im stuck between an ebay spec-D N1 look alike, The Apexi cat back runs around $500-$600 I believe but I do have a limited budget and opposed to the $150 Spec-D look alike, I may be going with the cheaper exhaust. I wanna know what my main differences would be considering the cheap exhaust. Ive read that there is some welding involved, But ive also read that it was a direct bolt on?
And in the long run would I be better off buying a nice lowering kit or just going with coilovers or something?
Hopefully you guys can shed some light on some of the things ive talked about, thanks.
Cat-back exhaust
Air intake(SRI)
Rims/Tires
Re: creating a steady base for modding
if you are not SURE what was done in the past and when, at your mileage i would replace the following as soon as possible.....in order of priority.....
- timing belt
- timing belt tensioner
- water pump
- coolant and thermostat
- tranny fluid
- air filter
- pcv valve
- spark plugs
- brake fluid
- power steering fluid
that should keep you busy for awhile
- timing belt
- water pump
- tranny fluid
- air filter
- pcv valve
- spark plugs
- brake fluid
Received 1,452 Likes
Rep Power: 340 Re: creating a steady base for modding
our cars are due for timing belt at 100k, so likely why it was for sale at 199k miles... so i would do that... (that would drive me to believe previous owner either bought it at 99k and wisely sold it at 199k, or she was the original owner and knew it was coming for the 2nd time, if latter is true, you are the second owner of this car )
add to above from mikey and you spark plugs, read here:
https://www.civicforums.com/forums/1...e-up-mods.html
suspension - start from the link in my signature
I will be moving your thread from the mechanical issues section, since it is not really an issue - don't worry, the experient guys uses the "new posts" function so they will not miss your post.
Rep Power: 232 Re: 02 EX - basic maint to creating a steady base for later modding?
no homo i miss gearbox seriously what ever happened to that guy he disappeared without a trace. i think we mite need to contact unsolved mysteries can any mods shed some light on this ???
Rep Power: 340 Re: 02 EX - basic maint to creating a steady base for later modding?
honestly, i don't know what happened to him... just rumours
BootyDo
06-21-2016 03:45 PM
alxz310
07-30-2015 12:18 PM
jzhartman
22
07-23-2015 10:42 PM
mokkush
07-14-2015 04:05 PM
