stage 4 clutch
Rep Power: 0 stage 4 clutch
I just got my 04 civic si and the previous owner put a comp clutch stage 4 in it. I don't plan on adding any upgrades if I replaced it with a stock clutch would I be able to sell the used clutch for anything or should I just leave it in there?
Received 1,148 Likes
Rep Power: 485 Re: stage 4 clutch
A stage 4 clutch, however, if someone felt the need to put it on, can probably yield a couple hundred bucks... good luck finding a buyer though.
Re: stage 4 clutch
have you ever used anything except a stock clutch? I'm pretty sure a stage 4 clutch would be a royal bitch to use. The force required to push in the clutch pedal would be ridiculous, and the engagement would probably be way too harsh for daily driving. I had a stage 1 clutch when I was turbo'd and my sister and dad had sore knees after using it. Stage 4 is overkill for a D17. I doubt there's much you can do to a D17 that can warrant a stage 4.
yes i realize all of that.....i have used many aftermarket clutches before, but he didnt say anything about the pressure being a problem for him
Rep Power: 0 Re: stage 4 clutch
Its not the pressure it takes to push the pedal that bothers me, its that it catches so fast its hard to downshift to slow down and shifting from first to second is a bitch
Received 1,442 Likes
Rep Power: 338 Re: stage 4 clutch
me thinks what happened was either:
1) Previous owner thought - i will put the strongest clutch in there with stock engine because i drive badass so the clutch will last (bwaahaha! yeah, right!) - reference the guy that put racing EBC pads and they never did come up to temperature so never did work well and did a mess of material accumulating in the rotors...
2) Previous owner put a clutch because he put a turbo and potentially you might be in trouble depending on what he did...
either way, there are really not many reasons to put a stage 4. maybe a stage 1 if one do autoX (not likely, too few runs to heat the brakes, even...) or track days from time to time.
or a stupidly high boost turbo, but then the engine might die way before the clutch does...
not aimed at you, maxpower, since you bought it as is.
just thinking how funny it is that so many thinks that since it calls for Race in the name, they should work... nope, they do not... some parts might work way worse because of that... (oh, man, here i go remembering again all the threads asking for the "best" this or that LOL! I will stop here...
lol I asked him why he went with the stage 4 and he said he was planning on building the car up but ended up just doing a cold air intake, exhaust, and the clutch
sesi
10-01-2015 02:03 PM
ThatGuy913
09-28-2015 05:35 PM
beanhead
09-24-2015 12:04 PM
Klame9420
09-07-2015 10:03 PM
