Sponsored by:
Sponsored by: DashLynx
Question about the OEM rear wheel hubs
Old 08-17-2011
I am Epic
Civicnoobie's Avatar
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
I notice my drums have holes next to the main holes where the lugnuts on the wheel hub are put through. THese holes are a bit smaller and i was told that theres suppose to be screws going through them and into the wheel hub, i guess for extra support is that true? Because right now i spin my drums and i literally have to press and hold the drum first against the backing plate for it to stick to it while spinning. Cause my wheel hubs on now (aftermarket) dont have the extra set of holes for screws and I looked at my OEM wheel hubs and they only have 4 main holes for the lug nuts, none for screws on top of that.
Do yours have the holes?
Like this.
Civicnoobie is offline
Old 08-17-2011
Whachya lookin at?
BlueEM2's Avatar
Re: Question about the OEM rear wheel hubs
wow dude
BlueEM2 is offline
Old 08-17-2011
I am Epic
Originally Posted by tbohar
wow dude
what?
Old 08-18-2011
I am Epic
no one knows?
Old 08-18-2011
Received 1,442 Likes on 1,198 Posts
god...
sdaidoji is offline
Old 08-21-2011
Honda Crazy
ZFreak's Avatar
ZFreak is an unknown quantity at this point
The holes are so you can adjust your rear drum brakes. When you have the drum off and the braking mechanism exposed, you cannot see the adjuster (self-adjuster) with the hub on except through these holes. Hope that helps.
ZFreak is offline
GolNat
Suspension DIY
05-12-2022 06:49 AM
edspyhill09
06-12-2016 02:45 PM
rtachs
07-16-2015 05:32 PM
oneheadlight
04-29-2015 11:30 PM
crazydragon
11-07-2001 05:13 PM
Quick Reply: Question about the OEM rear wheel hubs
