Sponsored by:
Sponsored by: DashLynx
Passenger Side window gets out of the rail
Old 06-19-2011
j3an_leo's Avatar
j3an_leo is an unknown quantity at this point
I have a Civic 01 LX, th problem is that my passenger side window gets out of the rail when is half way up. I have to hold it with my hand so it doesn't get out. I searched and I haven't found any post in removing the hole power window unit and window. Can some one post pics or a DIY site to se how to remove the window rail.
j3an_leo is offline
Old 06-19-2011
Re: Passenger Side window gets out of the rail
i have a similar issue altho the window hasnt actually popped out, just sounds like it will. you can remove the door panel and feel around for a loose rail. those things are very poorly designed and come loose all the time. i tried jb weld to hold it in place but it seems like the stress from the window is too much and it just came loose again.
gearbox is offline
Old 06-19-2011
CraigW's Avatar
^^^ and also clean the upper and lower rubber track insert and make sure it is in place correctly in the metal channel.
CraigW is offline
Old 06-19-2011
nsxvtec's Avatar
nsxvtec will become famous soon enough
You have to remove the door panel and pull back the plastic weather liner that sits behind the door panel on the door. A hair dryer or hot air gun used with care will allow the removal and replacement of the liner easily.
There is a 10mm. bolt on the rail that allows the window to be properly adjusted, preventing the glass from coming out of the track.
nsxvtec is offline
numbersguy
Electrical DIY
09-15-2018 11:24 PM
2HondaCivics
06-19-2015 12:06 PM
timpan
05-18-2015 07:06 AM
werdnahall
05-17-2015 11:37 AM
mwwhonda
11-07-2001 07:24 PM
Quick Reply: Passenger Side window gets out of the rail
