03 Civic ex auto stays in 1st gear. Please Help.
Rep Power: 0 03 Civic ex auto stays in 1st gear. Please Help.
RPM goes to 3.5k and still would not change to next gear. Check engine light is also on. What should I do?
I'm 200 miles overdue on oil change.
Rep Power: 0 Re: 03 Civic ex auto stays in 1st gear. Please Help.
first i would check to see if there is any atf in there...then i would find out why your check engine light is on....then go from there
Received 1,446 Likes
Rep Power: 338 Re: 03 Civic ex auto stays in 1st gear. Please Help.
the other way, i guess.
check engine light first. any autoparts store will read them for you, if you can get there, that is.
Hope you are using D, and not 1 in the shifter
1st gear is fun, i remember i drove one of those trd celicas from the port to the dealership all in first gear lol stupid auto lock gear
just a man with a civic
Trance Addict
Yeah. Sadly it sounds like it. I'd still check the fluid level and see if you can scan it regardless. One of the clutches or bands might be fubar, or something else in the tranny. That happened to my friend's auto one year.
Rep Power: 209 Re: 03 Civic ex auto stays in 1st gear. Please Help.
what if u put the shifter to 2 or 3? I would get the code for the check engine light, it probably has to do with the transmission not shifting. Then go from there
Have the same issue?
Might not be a toasted tranny, could be other things. Throttle Position Sensor comes to mind. It could be in limp mode for a variety of reasons that are fixable, and it would make sense to get a scan code for it first.
(Also, if you disconnected battery or took off the throttle body, could just need to relearn idle... sometimes it'll do stupid things like not want to shift out of park, or not shift out of 1st until it's relearned... I had to find that out the hard way, it was heartstopping lol.)
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
C6GrandSport
04-25-2015 09:41 PM
Blaster30
04-22-2015 12:21 PM
