Sponsored by:
Sponsored by: DashLynx
Can you remove just the lower portion of the timing belt cover for crankposition sen
Old 07-18-2016
Jacob Watts's Avatar
Jacob Watts is an unknown quantity at this point
Hi,
Fiance's car is having intermittent crank sensor issues. Looks like the mechanic didn't move the connector out of the way and let coolant flow all over it when we had the timing belt and water pump done almost a year ago. I got a new pigtail and knock sensor(figuring it corroded the contacts on the knock sensor itself also) and want to put them on.
Would be really nice if the valve cover and such didn't have to come off for just that one little part covered by just the lower half of the timing belt cover.
Jacob Watts is offline
Old 07-19-2016
mikey1's Avatar
Re: Can you remove just the lower portion of the timing belt cover for crankposition
you dont really have to remove the valve cover if you dont want to, you can just loosen the bolts and raise it up high enough to remove the top timing cover,
i dont think you can remove the lower cover without removing the top cover, the top cover overlaps the bottom one
mikey1 is offline
Old 07-19-2016
Thank you Mikey1.
I went out and figured I would try to remove the crankshaft pulley. I had the proper tool and such, two big breaker bars, and used a jack stand to steady the breaker bar I was pulling on. Couldn't budge it so she took it to a garage yesterday to have them do the work.
Old 07-19-2016
mikey1's Avatar
Thank you Mikey1.
i wouldn't even try it with a standard length breaker bar,
i use a 6 foot steel bar slipped over the breaker bar, even with that sometimes its still tough
mikey1 is offline
Old 07-19-2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Oh well. At least you showed some chivalry towards your fiancé in attempting to crack that crankshaft bolt.
NDNV is offline
btungcab87
19
02-20-2016 12:31 PM
Johny Roque
12-27-2015 11:05 PM
muttleytm
12-06-2015 04:49 PM
steve6
11-22-2015 08:18 PM
98hondaciviclx
10-30-2015 12:21 AM
Quick Reply: Can you remove just the lower portion of the timing belt cover for crankposition sen
