03 lx headligths come on by themselves
Old 03-01-2014
marek91's Avatar
marek91 is an unknown quantity at this point
Hey I have a 03 lx Canadian model civic so it has drl's. I have hid's in it that were installed over a year ago with no issue. Now recently in the winter when it has starting to warm up to just over freezing and my headlights now randomly come on with the car off and the switch in the cabin does not do anything the only way to turn the lights off is to pull the battery terminal.
any ideas ?
marek91 is offline
Old 03-01-2014
Super Moderator
Poopies's Avatar
Re: 03 lx headligths come on by themselves
Did you check the connection to the switch? If you have a relay box or something (idk how you are set up), it could be going bad.
Poopies is offline
Old 03-02-2014
mikey1's Avatar
is it just the headlights that come on? or is it ALL the lights?
mikey1 is offline
Old 03-02-2014
Since there is now an HID kit in addition to the factory wiring, that throws a lot of extra stuff in as possibilities.
Return the whole system to stock, see if the problem still exists. If the problem is gone, then it has to be something in your HID setup.
Next steps would have to involve knowledge of the system, the HID setup, and pointed testing at the time the problem surfaces.
(If ALL the lights come on, then it's probably not caused by the HIDs? Disconnect the main light switch wiring and see what happens.)
ezone is offline
h0nd4_r1c3r_X
18
10-19-2012 05:41 AM
02civic_rida
08-18-2006 05:30 PM
2002SilverEx
03-20-2005 01:39 PM
benjohn
Ottawa
03-03-2005 03:27 PM
CdKoInU
01-18-2005 11:27 AM
Quick Reply: 03 lx headligths come on by themselves
