Sponsored by:
Sponsored by: DashLynx
Lo/Hi beam issue
Old 12-08-2010
fripperiffic's Avatar
fripperiffic is an unknown quantity at this point
Lo/Hi beam issue
When switching from lo to hi beams, the lights often go totally off. Sometimes it will stay off for about 5 seconds, then the hi beams kick on. Sometime it works fine. Is this a fuse issue? It happens with both headlights. Sometimes it will switch from lo to hi no problem, but then it will cut out when on hi. Weird.
fripperiffic is offline
Old 12-08-2010
CraigW's Avatar
Re: Lo/Hi beam issue
Need info on car.
CraigW is offline
Old 12-08-2010
Kenny the Ricer
Kennykid2002's Avatar
Sounds like a relay/switch problem
Did you try disconnecting the bulb, and cleaning the connections?
Kennykid2002 is offline
ericaagarcia
06-11-2015 11:29 AM
Black91civic
06-06-2015 08:15 AM
intensity
05-12-2015 10:43 PM
Voiceofid
03-23-2002 09:56 PM
showoff
03-18-2002 12:19 PM
Quick Reply: Lo/Hi beam issue
