Sponsored by:
Sponsored by: DashLynx
window wont go back up. Honda 2001 lx
Old 04-21-2015
mdd5's Avatar
mdd5 is an unknown quantity at this point
Hey, i have honda lx 2001. im haveing issues one of the windows wont go back down what should i do?
mdd5 is offline
Old 04-21-2015
hokiedad4's Avatar
hokiedad4 is an unknown quantity at this point
Re: window wont go back up. Honda 2001 lx
This is most likely a wiring harness. We've got the same problem in our 2004 Civic LX. The trick that always works is to hold the window button in the up position while opening and closing the door. You'll get an intermittent connection and the window will roll up.
The wiring harness is not hard to replace, but I've got other repairs that are a higher priority.
hokiedad4 is offline
Old 04-21-2015
what should i do?
Read the quoted lines above.....
Make up your mind.
Figure out what the actual problem is so you can tell us what the actual problem is.
Then tell us which window has the problem.
There might be up to 4 windows to choose from.
Did you try it from both window switches?
Rear doors usually need the door harness, but sometimes it's something else.
ezone is offline
bsmiley
04-27-2015 01:27 PM
tylerginevan
04-27-2015 12:29 PM
dragonsblood
04-27-2015 12:28 PM
LionSpratt
04-26-2015 01:02 PM
jessicakaybby
04-20-2015 12:11 PM
Quick Reply: window wont go back up. Honda 2001 lx
