Cluster Instruments, Transmission Stick and Rear Lights not working?
Rep Power: 0 Cluster Instruments, Transmission Stick and Rear Lights not working?
<Problem Solved> Thanks for the tip guys, we ended up having to bypass the re-lay and got the SRS sign reset.
1 Post
Rep Power: 364 Re: Cluster Instruments, Transmission Stick and Rear Lights not working?
Sounds like a connector is loose or something..
As for the SRS light... do a SRS reset (search this site for how to do it). If that doesnt work, check the connectors under the seat. If that still doesnt work, I'm not 100% sure, but I heard autozone has a srs diagonistic tool
Rep Power: 0 Re: Cluster Instruments, Transmission Stick and Rear Lights not working?
Ah thanks. I'll remove the gauge cluster and double check the connections...there's also one more also...a random grey connector with black colored cable sticking out from between where the steering wheel area and behind the radio receiver dock is. I can try to post pictures later tomorrow...
Is there a way I can check if the airbags are working; without having to see a dealer?
Only a really random grey connector covered in black tubing behind the radio/center console.
You might post up what wire colors are used and # if pins that are in the connector. I could try to find some info.
I would measure voltage at the RED/BLK line of the cluster with the tails on (it is the source for the dimmer circuit) Shown as connector B16.
You could try the SRS reset and see if the light will stay off.
I got some pictures of what it looks like...here's a few...
Gauge Cluster not lighting up.
- Day: http://s28.photobucket.com/albums/c2...t=P1040058.jpg
SRS staying up.
- http://s28.photobucket.com/albums/c2...t=P1040056.jpg
Fuses; all is checked they're all good and working fine...
- http://s28.photobucket.com/albums/c2...t=P1040061.jpg
- http://s28.photobucket.com/albums/c2...t=P1040063.jpg
Random Wire sticking out?
http://s28.photobucket.com/albums/c2...t=P1040059.jpg
SRS staying up.
1 Post
Take the gauge cluster out and check the bulbs on the back and the two connectors to make sure all wires are in there, including the two black power wires.
SRS... check the connectors under the seat, and make sure the seat belts keep tension, and then do a SRS light reset, see if it comes back. SRS is due to the crash the car was in, probly wasnt reset by whoever fixed the car
Fuses... I think you might be missing a relay in the top right of your fuse box. I'll have to double check
Random wire.. where is that exactly?
@ Triz:
The 'Random Wire' thing was in the back where the center console is (the radio/stereo receiver and heater/A/C)...more specifically right behind the dash where the cup holders are...I can post a more specific pic tomorrow when there's light out...
As for the SRS thing I'm not too surprised...my dad kinda forced the car on me (long story short if he told me about it; I could've gotten the same care for 2k and fully working but without a backseat...haha...; we ended up wasting 3k+ on this car already) and the technician he had worked on the car was pretty cheap...
Cars History:
I'm the 4th owner. Daughter of the previous owner got sandwhiched in a car accident by two trucks; luckily minor damage and only the bumpers and trunk was damaged. However, she some how blew the old engine by not taking care of it and never changing/checking the oil...haha... So it's a new engine. Supposedly the new engine is also from a 2002 Honda Civic LX but the 4 door version? Mines a 2 door coupe... From what a few of my family (who work on cars) have said after checking it out said was that they must've messed up or neglected to re-connect some of the wiring after completely swapping out everything under the hood...or so I've been told...
Ah yea, again about the SRS. It's only supposed to remind me to fasten my seat belt if I'm sitting on it right? Whether or not the engine is on or running; I can get out of the seat or start it without never sitting on it and it reminds me to fasten my seatbelt. I checked the cables and wiring and everything seems fastened and fine...
Cars History:
You need to check voltage to the cluster at the RED/BLK wire I mentioned. If the voltage is not present you could isolate the wire and bring a line in from one of your tails or markers RED/YEL source or locate the wire near the under-dash fuse box and tie it in from there (both wires come from same source, see attachment)
Missing relay ?? Maybe 02s & 03s are supposed to use 2 headlight relays, it should not effect your dash lights (never say never) A quick free test is to move your horn relay into that spot and test the dash lights, then move it back to original location.
Connector is too hidden to be OBDII, and does not really look like keyless reciever connector. I cant see the wire colors to research.
1 Post
I have an 01 lx 2dr and have a relay in the top right position of the engine bay fuse box. Manual says its for the high beams.. do your high beams work? If not, put a relay in there to fix that, also swap over the horn relay (same size) and see if anything gets better.
As for SRS... srs is seat belts and air bags- all the stuff that protects you in a crash. There shouldnt be a reason your key should be in the ignition and turned on without you sitting in your car. I dont believe our cars have pressure sensors in the seats to tell if we are there or not. They only look to see if the seat belt buckle is clicked in. For instance- if the passenger buckle isnt clicked in, the air bag wont deploy on that side.
For the relay switch, it doesn't do anything on my car. We didn't notice anything change at all. However, the horn doesn't work either and the fuse works perfectly fine; we suspect the mechanic who helped restore the car did a half-assed job for us...
Lastly, how can I tell if the Cluster's light bulb is bad or not? I was only able to tell that they look pretty old, and some don't have anything plugged into them...
Thanks again for the help also everyone.
Also I've put more pictures on the first post...
If your horn is not working you better check your brake lights (they share a fuse)
The lights that you are missing are all the ones controlled by the dimmer circuit contained in the cluster... (the chances of all those bulbs being out at once is not likely)
ORskier
05-03-2015 12:54 PM
bahena08
04-11-2015 05:09 PM
