2013 Honda Civic Coupe LX map light
Rep Power: 0 2013 Honda Civic Coupe LX map light
Hi I am new here to the site/forum . I have noticed there is no button for the map light in the LX models of the civic to make it so that the map lights come on when one of the car doors is opened. Is it possible to add a switch to control to lights without having to link the map lights to the dome light?
2013 Honda Civic coupe lx no switch only bluetooth mic.
2013 Honda Civic coupe ex with the switch
p.s. is it possible to use switch from say the honda crz since it would better suit a car that doesn't have sunroof?
Re: 2013 Honda Civic Coupe LX map light
Creative. Wiring.
The LX is not prewired for what you want to do (at least my '12 sedan is not), so you have to do your own wiring.
IIRC, someone here installed extra LEDs into the front map lights and wired them to come on with the other dome light (with the doors).
Rep Power: 0 Re: 2013 Honda Civic Coupe LX map light
Thanks ezone.
Does anyone here have a 2013 civic lx that has bothered to look into their map light area? I only ask because I had no idea how the wiring is in the 2013 and it might be different from a 2012 model.
My schematic shows there is only a single wire at that map light set.
It is not prewired for what you want to do.
I saw on some other civic forum I think it was the 8th gen and the 9th gen civic that people split the wire from the dome light and connect them to the map light is it possible to add a switch, a custom one to control the function for map light?
The wiring diagrams are online now, that's it.
I'm old school, I am NOT a fan of online wiring diagrams at all.
You can purchase a subscription to Honda Service Express if you wish to get dealer level information yourself. I think there is some info about it on the Honda USA consumer website in the owners area.
HTH
OP, look in your current map lenses and see if you have an open square area like my 2010 does. I used 1 each side of the warm white stick-on LEDs from superbright and mounted them in that area. They are great !
No schematic required to tap into dome wiring just measure voltage or connect leds to test correct polarity. And do it right (no blue scotchblocks!!)
Pr0n1s
04-30-2015 03:08 PM
jessicakaybby
04-20-2015 12:11 PM
aZnVoYCe
Bolt-on Engine Performance
11-04-2001 10:18 AM
