8th Gen ATF Change
Rep Power: 0 8th Gen ATF Change
Hey guys,
My 2008 Civic is about to reach 80,000 miles and I have neglected to change the Automatic Transmission Fluid for it. I'm assuming I should right away, but my question is whether to do a drain and fill or just flush it? I have heard people mention pros/cons with each one. I'm getting nervous because when I drive my car seems to sort of shake or shudder when switching gears. It's not real bad, and not all the time, but I definitely feel something sometimes... Especially in a lower gear. I want to keep my car for quite a few more years and I drive about 20,000 miles a year, so any info on what I can do would be helpful.
Thanks
Thanks
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Rep Power: 164 Re: 8th Gen ATF Change
I would just do a drain and fill, if you are worried its not enough do it again at the next oil change as well..
Yes the 8th gens can develop TCC shudder.
The Civics I really notice it on are the ones that neglected the trans services.
We (the shop) always recommend ATF services at least every 30k because of situations like this.
Drain and fill only.
Use factory fluid DW-1.
About 2.75 quarts per drain and fill.
If you want to flush, official procedure is multiple drains and fills until a case of fluid is run through.
Search this site for a link to the procedure.
Never use chemicals to flush.
DIY is safer than any JizzyLube.
Rep Power: 0 Re: 8th Gen ATF Change
Here’s a link to the official flushing procedure (from a different forum, but it's the same procedure for all Honda models with AT).
http://www.ridgelineownersclub.com/f...30&postcount=3
If you read the steps carefully, it calls for 4 drains & fills overall. Also, note that the Z1 AT fluid has been discontinued and replaced by Honda DW-1 fluid as mentioned byCraigW and ezone. Otherwise, the same procedure applies.
Thanks everyone for your help, awesome answers, just what I was looking for! I think I'll definitely go the DIY route, so it's great to have some feedback on that as well.
chuffsy
05-16-2015 03:52 PM
markp94
04-30-2015 09:19 PM
SaiyanMatador
01-06-2002 10:49 PM
8th, 9th, atf, change, civic, discontinued, fluid, gen, honda, replace, replacement, replacing, si, transmission, z1
