8th Gen 2006 - 2011.
Wheel Bearing Torque?
Old 08-17-2016
TheZodiac's Avatar
TheZodiac is an unknown quantity at this point
I am replacing my rear Wheel Bearings this weekend on my 09 Honda civic LX-S,
Does anyone know the torque specs for the 4 bolts?
thanks
TheZodiac is offline
Old 08-17-2016
Re: Wheel Bearing Torque?
Are the bearings actually noisy, or is the tire tread all choppy and making noise?
Ate up tires is pretty common.
The 4 bolts-- hub to knuckle --47 ft-lb
ezone is offline
Old 08-18-2016
TheZodiac's Avatar
Hi Ezone, thanks for answering, yes I can hear them on the highway. The tires are fine, I just had them balanced at a tire shop. and another thank you for the torque spec :0
Old 08-31-2016
digger's Avatar
digger is an unknown quantity at this point
I also have an 09 civic and there seems to be abnormal road noise from the rear, mileage 38,000. Factory tires. I'm thinking the rear wheel bearing should be inspected and regreased at a minimum. ANy thoughts would be appreciated.
Digger
digger is offline
Old 08-31-2016
TheZodiac's Avatar
Digger
I don't think you can regresse the wheel bearings on Honda civics. My issue turned out to be scalloped tires
Old 08-31-2016
Prelude Owner
GolNat's Avatar
The wheel bearings are probably sealed so can't grease them.
I would have your tires/alignment checked out first. More common of an issue.
GolNat is offline
Old 08-31-2016
Digger
Tire tread is worn --severely choppy.
ezone is offline
Old 09-01-2016
digger's Avatar
THanks everyone. Another question. WHat mileage should I be looking at replacing shocks? ANy recommendations there. Monroe?
digger is offline
Old 09-01-2016
Don't bother to replace until truly needed. (Leaking a lot or excessively bouncy)
Many of our stock struts and shocks can outlast the cars they are bolted to. Others may not, but there is no rule saying to replace at a certain mileage.
Monroe? Not on my cars. There's a reason they want you to replace every 50k, and it isn't because they sell a great product. Make sense?
ezone is offline
Old 09-01-2016
Prelude Owner
GolNat's Avatar
I'll have to remember that one.
KYB/Koni/Tokico are the better options but no reason to replace if they are not bad.
GolNat is offline
OptimisticWay
01-03-2016 07:54 AM
mike1072
11-14-2015 05:42 AM
trv020
10-28-2015 10:37 PM
whiteformula98
10-25-2015 07:00 PM
ayzan
12-28-2001 10:47 PM
Quick Reply: Wheel Bearing Torque?
