8th Gen 2006 - 2011.
07 bulbs replace- pass. side HOW???????
Old 02-23-2007
YOMAN's Avatar
YOMAN is an unknown quantity at this point
I got me 07 Honda EX 4 dr and loving it...
I replaced all bulbs to SIlverstars and i ran into problem, its on passenger side, i cant reach 9006 bulb cuz of power steering is in the way.
How did you guys replace it ?? remove power steering huh?? will it hurts aluminun tubes (ie, bend etc) ??
Thanks!
YOMAN!
YOMAN is offline
Old 03-02-2007
aesop's Avatar
aesop is an unknown quantity at this point
I would like to know how to replace the passenger side headlight bulbs too. My manual only show how to replace the driver side headlights. Odd since the passenger side headlights do burn out.
aesop is offline
Old 03-02-2007
electric130's Avatar
on the 7th gen, you have to pull the reservoir up out of the way. don't know if yours is like that. a couple clear pics would help.
electric130 is offline
Old 03-02-2007
YOMAN's Avatar
ON pass. side, i unscrew the bolts that hold box ( i think brake box) with few alumiun tubes then pull toward driver (go easy on it) then other hand go in there to remove it then plug it in.
YOMAN!
YOMAN is offline
Old 03-13-2007
silver06civ's Avatar
silver06civ is an unknown quantity at this point
bulb replacement
on the pass side of my 06 2door if u pull the top half of the windshield washer resivor out then u can get into the area to get the bulbs out easier, its a pain, they build a car around a motor nowadays
silver06civ is offline
Old 03-14-2007
you wanna see PITA? come work on an F-16 with me for a day! them bitches SUCK!!! i've got the scars to prove it!
Old 03-25-2007
cyager's Avatar
cyager is an unknown quantity at this point
Re: 07 bulbs replace- pass. side HOW???????
I put silverstar ultras in my 06 civic...... on driver side just unscrew the battery mounting rod, tilt battery, then resivoir pulls straight up and out. This will give you great access. Passenger side, crank wheels all the way to one side... pull out plastic wheel housing cover out about 5 inches(it wont break, it bends) then you have lower access to headlights.
cyager is offline
Old 04-04-2007
mysterymanmarty's Avatar
mysterymanmarty is an unknown quantity at this point
has anyone switched fromt the silverstars to the silverstar premiums , any real difference , i couldnt find the ultras so the went with the regular
mysterymanmarty is offline
Old 04-16-2007
20strong's Avatar
20strong is an unknown quantity at this point
I changed mine when I pulled the heads out to clear them but I am using premiums and the light is great I love it.
20strong is offline
Poopies
04-20-2017 11:36 PM
MamaBear2015
06-11-2015 07:33 PM
terry_tr6
HIDs and Retrofitting
05-16-2015 08:37 AM
Hondasport01
12-17-2001 01:53 PM
Quick Reply: 07 bulbs replace- pass. side HOW???????
