White smoke
Old 07-07-2016
R4PTOR's Avatar
R4PTOR is an unknown quantity at this point
White smoke
Hey, just bought a used 1995 civic coupe ex. I was looking at different reasons as to why my car shakes and the speedo has the needle slightly bouncing on 1000 rpm in idle. Found my way to the fuel system hose behind the engine, and the clamp wasn't attached properly. so when I reattached it, immediately white smoke started coming out of my exhaust. There is also a black like substance coming out of it. I also noticed that because the previous owner had it so dirt nasty low, what looks to be the cat looks loose with some type of cloth coming out. Haven't jacked it up to look yet.
also, there is oil that seems to be sort of wet but just lightly caked on the front of the engine block. under the valve cover.
OptimisticWay
01-03-2016 07:54 AM
mgcivicdriver
Engine start problems
16
12-10-2015 11:58 PM
rford65
11-22-2015 11:22 AM
99BoostedSi
11-03-2015 06:32 PM
R Steele
10-22-2015 05:09 AM
Quick Reply: White smoke
