Ramps or jackstands?
Old 10-04-2011
Matt Bachand's Avatar
Matt Bachand is an unknown quantity at this point
What do most of you guys use for changing the oil on these?
Old 10-04-2011
Prelude Owner
GolNat's Avatar
Re: Ramps or jackstands?
Ramps. It's really personal preference.
Old 10-04-2011
sl33pyriceboi's Avatar
rams or jackstands are undoubtedly person preference
but it is unarguable that jackstands are much safer than ramps.
and that is why i use jackstands.
Old 10-04-2011
lowlife9's Avatar
i use ramps for engine oil and other small stuff its jusy easier jack for tranny fluids and wheel stuff.
Old 10-04-2011
just remember ramps are not for lowered cars (i tore up my front bumper on the way down) and they are very scary to drive up onto. i say go with jackstands on each side, lower the car so that it is touching but not being supported by the stands, then keep the center of the car loaded on the jack. and slide a ramp under each side of the car as a last resort fall protection. and yes i have heard of jackstands and jack failing before. not often, but it does happen.
Old 10-04-2011
Live for the Twisties
MindBomber's Avatar
Jack stands.
I can't get my car up a set of ramps though, to low..
Old 10-04-2011
x2. i would need a very long and gradual increasing ramp.
Old 10-04-2011
Sedans > Coupes
Brian1037's Avatar
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
My car at stock height was too low to go up the ramps already here. So I used stands for a while but for my last oil change I got some 2x4's and did some make shift work and managed to get up on the ramps. Scary as hell getting up there and I surely burnt some clutch because I didn't want to fully engage into gear.
Old 10-04-2011
lazlong's Avatar
Stands. Stock height is too low on these cars, you'll tear up the bumper.
Old 10-04-2011
lowlife9's Avatar
they make ramps for lowerd cars race ramps though there expensive 200+ dollars or you can make your own out of wood very simply and cheap
http://my350z.com/forum/brakes-and-s...ered-cars.html
Old 10-04-2011
lazlong's Avatar
^^ 3" isn't gonna do **** for me. How the hell can you get to the oil filter with 3" more clearance? I mean I'm skinny but, not that skinny. lol
Old 10-04-2011
lowlife9's Avatar
lol thats just a reference on how it could be done with wood that guy just made those so he could get his jack under it.
Old 10-04-2011
lazlong's Avatar
^^ Ah... ok, gotcha. I spent $250 on a low-pro jack with collapsible handle so it'll go in the trunk 'cause I literally threw out my back lifting the car to get the jack under there when I had a flat. These suckers are heavy when you have to lift it by yourself. lol
Old 10-05-2011
lowlife9's Avatar
you should get one of these they inflate off your exhaust
http://www.airjackusa.com:80/contact.htm#order
Old 10-05-2011
i cant clear ****.
i can BARLY get my 1.5 ton aluminum low pro jack in there.
Old 10-05-2011
lazlong's Avatar
^^ Good luck changing a flat tire. lol
Old 10-05-2011
MindBomber's Avatar
I use a scissor jack to lift my car up enough to get my real jack under lol
Old 10-06-2011
01EX5speed's Avatar
01EX5speed is an unknown quantity at this point
the stock height of our cars are way to low..i ended up borrowing my friends jack...jacking up both sides and then sliding the ramps under and driving up the rest..burnt my clutch..really risky but it worked lol
Old 08-24-2015
Metallic1's Avatar
Metallic1 is an unknown quantity at this point
hey guys, 1st post, just bought an 06 civic lx, 2 door,
from an older gent who took very good care of it from
day 1., 151,226 miles on the clock, the car is black,
looks and runs fine!
anyway, i dont mean to bump an old thread, but cut
a few lengths of 2x6 lumber, stack 2 lengths staggered in
front of the tire, and drive the front tires onto them.
then you have about 3 1/2 inches added height to get your
jack under the car.
great info on this site, im learning a lot!, thanks guys!
juror
Suspension DIY
07-30-2019 03:28 AM
mjdiaz89
06-21-2016 09:26 PM
rovafa2002
09-28-2015 06:57 PM
vImpostor
Vancouver
09-08-2015 08:08 PM
Q-Bert
07-19-2015 09:09 PM
Quick Reply: Ramps or jackstands?
