Bought 2001 civic LX with 113k and need maintenance advice
Old 03-08-2010
TravisJohnson's Avatar
TravisJohnson is an unknown quantity at this point
Well now that i have bought this honda, i am really starting to take a lot of interest on working on my own car. its a 2001 civic LX manual trans.
So far ive changed the oil and changed the cabin air filter (which hadnt seen the light of day since the assembly line stuck it in there).
I tried to take the air filter out, but ran into the dreaded cracked pastic...and i CAN NOT get that dang thing off there without breaking it apart. very dissapointing becase im sure the air filter needs to be changed.
But my question is what are some of the things some of you more experience owners would do to a car with 113k on it? i have no history of whats been done to it in the past.
thanks, travis
Old 03-09-2010
lowlife9's Avatar
Re: Bought 2001 civic LX with 113k and need maintenance advice
i would be very concerned if the timing belt had been replaced along with the other stuff that usually gets replaced at the same time like timing belt tensioner,water pump etc etc.
Old 03-09-2010
so your saying i should get the timing belt checked?
I took the car to a local mechanic today to see if he could get the air filter cover off, and he worked on it for about 15 mins and then flat out said he couldnt help me. I'm begining to think just paying the 250 for a cold air intake would be the best choice
Old 03-09-2010
CraigW's Avatar
It would be wise to know if it has been or not. They may have bailed on the car to avoid the 110k service.
Take a look at the drive belts in the bay...how many cracks are present on the inner ribs ?? If they were done recently there would be none or just a few. If the belts are cracked heavily, then most likely the work has not been done (its a huge gamble on a belt driven interference type engine over 110k and 9 years of age)
Old 03-09-2010
alright ill check out the condition of the belts next time i get a chance. and yes i know, but i paid cash for the car, and thats better than having a perfect car with a 300 a month payment.
Now im seriously considering ordering a cold air intake because i cant get to the stock air filter. I know there are some really nice and expensive ones, but what can i get for around $150 that would be best?
Old 03-09-2010
lowlife9's Avatar
get a cheap ebay pipe and relace the filter with a AEM dry flow and as for the timing belt you may have got the deal of the century but if that belt snaps your screwed.
Old 03-09-2010
screwed as in a major repair?
and alright i think im just going to order a pipe off ebay
Old 03-09-2010
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
Mine snapped around 117k miles, 2 1/2 years ago. I would make every effort to check that out. The repair was about $1,500. and now the engine is screwed, currently looking to swap it out. I have to do valve adjustments every ~5,000 miles and the Crankshaft journal bearings clicking like a Mother Effer, driving me insane from the noise they make.
Aside from that critical maintenance, you may want to look at new struts, I replaced mine @ 90,000 miles and there was nothing left of them, makes a huge difference on the ride quality and safety. Depending on who drove it, they clutch may have some good wear on it.
Anyways, just check out the timing belt issue. You do NOT want that thing breaking on you.
Old 03-09-2010
Keepitmovin's Avatar
Keepitmovin is an unknown quantity at this point
Spark plugs and MTF are easy maintenance at home and just go with a sri instead of a cai.
Old 03-10-2010
oh wow....alright ill have to get that timing belt changed right away. see, you guys have me a little paranoid now lol.
i thought about doing the spark plugs soon. I just hope i tighten them correctly
Old 03-10-2010
Well i have an appointment to get the timing belt changed for tomorrow morning. He said parts & labor it should be a little under 300 bucks. not too bad really, especially since it NEEDS to be done.
Old 03-10-2010
MidnightCivic's Avatar
You might as well do the whole tune up, i didn't do mine till i was @ 120k or so..no need to rush the timing belt.
Here is a list of what i did to it:
timing belt
water pump
crankshaft seal
camshaft seal
valve cover grommets(5)
valve cover gasket
AC / alternator belt
power steering belt
3 qrt of OEM Honda ATF-Z1
I also upgraded my brakes recently...
Old 03-10-2010
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
timing belt
water pump
crankshaft seal
camshaft seal
valve cover gasket
power steering belt
What did this cost?
Old 03-10-2010
Originally Posted by joe6680
What did this cost?
Bought most of it off ebay as a package all oem tho from an actual honda dealership selling on ebay. Cost me around 150 total for parts
Old 03-10-2010
laack's Avatar
laack is an unknown quantity at this point
300!! thats a steal
Ive never been quoted less than 700! I'm planning on doing/attempting my own this spring when it warms up a bit. what state do you live in?
Old 03-10-2010
lowlife9's Avatar
thats just the one belt and nothing else you need to replace the timing belt tensioner also thats important . along wth the water pump and all the other belts while everything is disassembled.
Old 03-10-2010
I live in tennessee, but the work is being done in kentucky like 15 mins from my house. and yes the 300 is including the tension springs and entire kit. I wish i would have known to tell them to do the other belts while the car is taken apart, but its probably too late now because they would have to order the parts and im going in at 8 tomorrow morning.
after this its the rims.....but i think im going to stick with 14' because the tires are brand new and i would hate to have them go to waste for a couple extra inches of ballin-ness.
Old 03-10-2010
lowlife9's Avatar
thats strange the tensioner olone cost me 125 dollars wiyh my discount at napa there usually 190-200 dollars i dont no it doesn't sound rite i mean 300 sounds like the labor alone you must have the cheapest mechanic in the world.
Old 03-10-2010
lol i do live in a really poor area of tennessee. he said 30 for the belt, 75 for the tensioner kit, and 150 for 3 hours of labor. and this is a legit place, not some hole in the wall. But ill be sure to post tomorrow when i get hit with the 500 dollar bill due to some sort of miscommunication lol
Old 03-10-2010
lowlife9's Avatar
dam thats cheap for labor around here the cheapest ive found is 85 dollars an hour im jealous maybe the work quality mite not be there.
Old 03-11-2010
I'm not really worried, i honestly believe that they just cant charage outrageous prices around here because people just dont have the money.
Do you think the car will run better with a new timing belt and tension setup? or is it just one of those things that you can't tell its been done
Old 03-11-2010
lowlife9's Avatar
na you wont feel anything except the feeling of security that its been changed
Old 03-11-2010
Well i had it done. I talked to the mechanic about replace the other parts, and he was totally down. New timing belt, tension kit, water pump,anti-freeze, and accesorry belts for $400.99.
The car REALLY drives better now
Old 03-11-2010
lowlife9's Avatar
is it automatic ???
Old 03-12-2010
nope its a stick shift
Old 04-01-2010
g2s
g2s's Avatar
g2s is an unknown quantity at this point
Is the price quote from honda dealer?
Old 04-01-2010
g2s
g2s's Avatar
Originally Posted by utahbmxer
Mine snapped around 117k miles.
Mine 2001 civic is already at 115K and never had timing belt change. I am worried to know your timing belt snapped at 117K. I live in California with nice weather. Hopefully, that factor give me a bit more time to have enough money for a timing belt change. Where do you live?
mattdoc
03-14-2017 12:10 PM
vtechcivic
04-21-2015 07:11 PM
CapYoda
11-11-2001 05:17 PM
Lightman
11-10-2001 06:44 PM
liljoe
11-04-2001 01:27 PM
Quick Reply: Bought 2001 civic LX with 113k and need maintenance advice
