aluminum base bushings
Rep Power: 0 aluminum base bushings
i just installed my revo ss today and also attempted to install the alumnium bushings from strutking. for some reason, once i put the top layer of bushings, the screw does not reach the thread so i cant screw it in, so i was wondering if there was a difference between leaving the top part free of bushings, would that damage anything? ( the bottom has aluminum bushings)
03 Civic EX
Rep Power: 0 Re: aluminum base bushings
I'm assuming you bought the second generation of the Revo SS and unless i'm mistaken they re-designed it to eliminate the bushings all together. Therefore you shouldn't need the aluminum bushings that were a huge upgrade with the first generation Revo SS. I'd try removing the bushings and see what you get.
ThatGuy913
09-28-2015 05:35 PM
OptimisticWay
09-18-2015 09:37 PM
AffliictiioN
09-16-2015 02:21 PM
