lots o lots o k parts
"mmmBAHHHH" - vtec y0
ok so ive decided its time to clear up some stuff i know i will not be using in my upcoming build and try to put some funds back into the project. pictures were taken last week via my cell phone so if anyone wants better pictures of different angles of an item all you have to do is ask....nicely lol :-)
prices DO NOT include shipping or paypal fees local pickup is accepted and encouraged for the larger items. will drive within certain distance for serious buyers yadda yadda yadda those are all details we can work out later. ok so onto the loot.
02-04 Acura RSX Type S Moog Outer tie rod ends. *Brand new, just installed for test fitting some things* im fairly certain the castle nuts and cotter pins that came with it are in use but i can provide castle nuts and cotter pins if you really need them.
50 OBO for the pair. pretty sure just one was about that much at the parts store.
01-05 honda civic lower control arms.
The compliance bushings are toast perfect set to put some spherical bearings or hardrace bushings in with no downtime for your current ride.
lets say 60 OBO for the pair *will not separate*
3 Type S coil covers 1 missing the A
10 a peice
2 Type S 1 k24 timing covers
40 a peice 2 are missing the inspection plates
2 Type S 1 K24 water pump housings. the type s ones come with water pumps although i would recommend changing them.
40 a peice
set of 02-04 Type S cams and rockers. these are locally pending but i figured id put them up anyway. i can take better pictures if you like i was in a hurry when taking these.
flash made that photo look weird
200 obo
02-04 Type S throttle body all sensors everything in great condition.
150
Disassembled K24A8 block unsure of mileage but it is in good condition. with everthing there to assemble back to oem. was going to build this block but ended up going a different route. the person who disassembled this put everthing in labeled plastic bags so reassembly should be a breeze.
some very slight surface rust on the cylinders walls since putting it my storage unit.
what ya see is what ya get. from what i can tell everything is there
200 OBO
you can pm me on here i will be checking it daily. thanks for looking!
10 a peice
40 a peice
200 obo
150
200 OBO
usajags84
15
Aug 19, 2015 03:12 AM
2k1Vtecivic
Nov 3, 2001 10:37 AM
