Suspension Post your issues with Suspension here! Suspension will cover from Steering Column (Steer Wheel is in interior), Suspension, Bearing and Hubs
Noise with genuine shocks
Old Aug 3, 2018
plateau's Avatar
plateau is an unknown quantity at this point
Hi, people, are you all ok?
I'm from Brazil and I have a Civic EX 2005 and I would like to share a doubt about its suspension.
30 days ago I have replaced theses items ahead:
1) Front shocks (genuines);
2) Strut mounts (genuines);
3) Bearings (genuines);
4) Coil Springs (Fabrini).
After replacing, I realized that ground clearance was huge (the tire clearance was more than 4 fingers).
So, when I pass through a big speed bump (or a short speed bump with a speed higher than 20 Km/h) or over a wavy asphalt a usually hear a noise like a "TOK" or "CLOK". It only happens in these situations.
I have talked with a guy from Honda Auto Center and he told me it is normal because the genuine shock absorber has a short range piston and springs are brand new.
So, is this really normal?
I hate to hear any noise in my car and I always choose genuine parts to avoid these situations.
Thanks in advance, folks.
Regards,
Peter.
Old Aug 3, 2018
BrotatoChip's Avatar
Super Moderator
Re: Noise with genuine shocks
I would also check sway bar links and control arm bushings. Either one can cause noise over bumps.
Old Aug 3, 2018
Center nut not tight enough?
Old Aug 3, 2018
plateau's Avatar
Many thanks for having replied me too fast, my dear.
I forgot to mention, but I already have replace both control arm bushings and I have removed the sway bar to ensure the links weren't the problem.
Even though trying these tricks, the noise keeps appearing.
More than 1 year ago I have replace some other parts. They were:
1) Ball joints;
2) Sway bar links;
3) Control arm bushings;
4) Inner and outer tie rods;
One more time, thank you so much.
Regards,
Peter.
Old Aug 3, 2018
plateau's Avatar
Well... I really don't know.
However, I have bought a new pair of TRW brake discs and I will replace the old ones as soon as possible.
Old Aug 3, 2018
I meant the one big nut on top of each strut that holds it all together. Sometimes it's difficult to get that tightened properly and it can make a lot of noise if it's not.
Old Aug 3, 2018
plateau's Avatar
Ahhhh ok... I thought you were talking about the wheel center nut.
I will check and try to tight it again.
Sometimes I think this issue is related to the ball joints. However, they were replaced by TRW ones in 2016 when my car was wearing KYB shocks (they leak in 2017 and I decided to buy genuine shocks to replace them).
Old Aug 3, 2018
plateau's Avatar
I just checked the center nut and it is very tight.
Old Aug 3, 2018
check if the springs have been properly indexed.
https://www.civicforums.com/forums/4...like-pics.html
Old Aug 6, 2018
plateau's Avatar
Many thanks for your reply, my dear.
I followed the service manual during the assembly and I think I did everything right
Even though I have chosen the TRW ball joints (here in Brazil they are a very nice manufacturer), I'm thinking they could be failed (they are +- 1 year old). However, some months ago both boots were ripped because their rings went to a wrong position and cut the rubber. I found another boots, put more grease and replace the old ones (they seemed to be ok when I checked them (no loose or worn)).
I will just add some pics to try to describe better.
Front tire clearance
Rear tire clearance
Ground clearance
Old Aug 6, 2018
Why is one side 5cm higher than the other/.
Old Aug 6, 2018
and... you need new tires and alignment...
urgently...
Yeah, TRW are good.
ezone, the pictures with the fingers, one shows the rear, the other the fronts
plateau... Tu ta no centro, tipo Brasilia, Goias?
usual things that cause knocks after suspension replacement: Sway bar endlinks and top mounts.
Old Aug 6, 2018
plateau's Avatar
Did you mean between left and right or front and rear side, my dear?
In the front, the clearance is almost 6 fingers and 4 fingers in the rear.
But the clearance between left and right is the same (I think).
Old Aug 6, 2018
plateau's Avatar
urgently...
Yeah, TRW are good.
Hi, bro, are you brazilian?
I'm from Belo Horizonte (700 Km fron Brasilia and 600 Km from Sćo Paulo).
In the last weekend I replaced all tires and the alignment has been done. I have bought the tires on the internet and the delivery was so late.
To ensure that the sway links were ok, I had removed the sway bar (with the sway links too) and the noise kept there.
The strut mount are genuine and brand new. Is there any chance of failure? ( I have replaced the shocks and struts only one month ago )
Old Aug 6, 2018
then inspect the control arm bushings. If the rubber are torn, it could be the cause.
Sim, sou paulistano
Old Aug 6, 2018
plateau's Avatar
Sim, sou paulistano
Very nice, bro!
I will try to disassemble the LCA during the night to inspect better the rear bush. I really think the front (the bigger one) is ok.
Is there any chance of noises when passing through speed bumps if the tie rod has a free play? The driver's side was looser than the passenger's side.
Old Aug 7, 2018
Super Moderator
What do you mean free play? The outside of the tie rod has a small ball joint so it can swivel a little but there shouldn't be any other movement besides that.
Old Aug 7, 2018
plateau's Avatar
I will record a video to explain better about this "free play", my dear.
Thank you so much for your cooperation.
Old Aug 7, 2018
plateau's Avatar
Hi, folks.
I decided to remove the LCA to check the bushes and the ball joints and I realized that the rear bush is broke/cracked and the front one has no resistance to move (is very easy to move it using a screwdriver).
Further, I recorded a video to explain better my doubt.
P.S: I have checked all ball joints and the tie rods and both seem to be ok (no looses or worn).
Old Aug 7, 2018
Front bushing is supposed to be easy to move, the center is only connected with the two strips of rubber.
It looks like the two parts of rubber on your bushing are not torn badly yet? Difficult to see in the video.
If its rubber were torn completely apart the forward end of the lower control arm would be able to move freely up and down and make unwanted contact against the subframe (clunk noise) upon bumps in the road
Found this pic of a badly torn bushing on google image search:
Old Aug 8, 2018
plateau's Avatar
Hi, my dear, are you ok?
The front one is starting to rip in the edge. Further, the rear one is completely ripped.
So, these things could cause the issue (clunk noises) when hitting or passing through a speed bump?
Old Aug 8, 2018
Torn rear bushing could be a possible cause of noise, yes.
I believe your forward bushing has not yet ripped badly enough to allow the arm to drop and contact the subframe.
But you already have the control arm out of the car so if you intend to replace one bushing you may as well replace both.
Be sure to neutralize the control arm upon reinstallation so the new rear bushing is not preloaded causing premature failure.
Old Aug 8, 2018
plateau's Avatar
Roger that!
The incredible is this clunk noise only happens when I hit a speed bump. If the pavement is wavy I don't remember if I have heard it.
So, that's why I think both things (a soft rubber in the front bush and a ripped rubber in the rear) can cause this issue.
Here in Brazil every genuine part in Honda is very much expensive. The cost of this pair of rubber bushes is +- US$200. Further, if I decide to import from USA, the shipping is high and the customs fee is close to 100%.
I will try to buy a new pair of LCA from Monroe this week and replace the old ones.
Thanks, bro.
Old Aug 8, 2018
When assembling new front struts/springs etc., did you install a new stopper (bump stop) to the shaft of the shock?
If this parts catalog image displays correctly below, it is item #8
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAA8wAAAHmCAIAAAA p4pBAAAAgAElEQVR4nO3d25rsKm+o4br/m3YOxh+3JxshsRXwvQfr6a62QcgCa1Rmsn4PAAAAgK5+qwMAAA AATkOTDQAAAHRGkw0AAAB0RpMNAAAAdEaTDQAAAHRGkw0AAAB0 RpMNAAAAdEaTDQAAAHRGkw0AAAB0RpMNAAAAdEaTDQAAAHRGkw 0AAAB0RpMNdPPLiP/0vX5pyP8Th5Rby1DJwIS/AphjyYHg3+rHAu8oEaCP1af9IYSUkm1sTS5gjpRNjXib4BjUB9 AHpy0AXIVjHzLqA+iD0xYArsKxDxn1AfTBaQsAV+HYh4z6APrg tAWAq3DsQ0Z9AH1w2gLAVTj2IaM+gD44bQHgKhz7kFEfQB+ctg BwFY59yKgPoA9OWwC4Csc+ZNQH0AenLQBchWMfMuoD6IPTFgCu wrEPGfUB9MFpCwBX4diHjPoA+uC0BYCrcOxDRn3A7CdaHd0aN6 8dAO7EsQ8Z9QEDub2+udW+c9UAcDOOfcioD6goG+hr++wLlwxg F3ceyxOQUsioD6gEB7T87fWFp/mFSwbgH/+TxqFIJmTUB8qCozl5TBcvONuFSwbgXNBY02d3RyYhoz6gwjfZ sguXDMC54hciaEQmIaM+tpHrZed8OSE007mQxgXj04VLBuBZ8t uQO8/nQcgkZNTHHuQed1qTrY/kwqPnwiUD8IwmezQyCRn1sYdvg/v9cNoO/86Va7jjC65y4ZIBeJY8iu88nwchk5BRHzuJm+yZ8xanpsleHQI A/OGb7NHIJGTUx06S32RPODfjb6w1TfZtR/lViwXgH99kj0YmIaM+dpJssr8/Bxte+BqjwnfG3MGdvOsSVy0WgH/CS2FVSIchk5BRHzsJDsfk6TlnXrkXf+47yq9aLIAtFA9qNCKTk FEfO5EPx9FNdu4bEfmvI+Jx6KrFAtjCey59D2QOq47IJGTUx07 ib5SFv3afV9M3X/t9yVWLBbCF5LnEYdURmYSM+thJ3GT/pvznGfHXIbLR8Th01WIBbEE+pdGOTEJGfewk2WRPODet4194jt +2XgD+5c4lDqteyCRk1McJ5uxzuaG//JuSC5cMwDm+yR6NTEJGfcBAOLIvP76vXTgAt77n0vszh1VHZBI y6gP1bu6qA+QBgDfxdx8c2n2RScioD6AD3lsAvOF/3jgamYSM+gA64L0FwJvkucRh1RGZhIz60FL+58hnExJCrn6ctg A8CU4nDqvuyCRk1IdW8bSas9ne2R91L1sx7PdzYaitz+vgwSXz Fqzu99//rvHhpQXAsdwbgfOqFzIJGfWhxV4CAGxE+HJkSTznIZOQUR9a7C UAwEaSry2a7I7IJGTUhxZ7yaruP1wBAHRBkz0amYSM+tBiLykl/ytAWm0AmIwmezQyCRn1ocVe0kg208H/viCZBIAJaLJHI5OQUR9a7CWN7/Gd+w6bIx4AJqDJHo1MQkZ9aLGXNIRO+ttqk0wAGI0mezQyCRn1 ocVe0vi20cJ/kE0yAWA0muzRyCRk1IcWe0kj+R9k5/4bkkUxAsAVaLJHI5OQUR9a7KWi4D8IKf66OFwAOBpN9mhkEjLq Q4u9VKT8lppvsgFgAprs0cgkZNSHFnupKPcfZMefcMoDwGg02a ORScioDy32UlGxq/7997/MXhosAByOJns0MgkZ9aHFwVSk+Zaab7IBYA6a7NHIJGTUhxYHU 1Hxa+zgq+7V8QLAyWiyRyOTkFEfWhxMsvg/CMldE188OqpcqDxQAKfKHXEcfR2RScioDy0OJlmQHw9NdnKW5N fqAHAS4Xzj9OuIHEJGfWhxJAniU1vZZI9LaXKKXM89KAYAmKz4 JQLfMnREAiGjPrQ4jwTK7jn465yUylPwWAGcJPiyIz7f4uN6do gHIXuQUR9aHEaC5BfGObm7JgRm+isAbEdzGucuhhXZg4z60OIw ElR8IyI34tWSs3QJGAD8059sHIPtyB5k1IcWh5FA7nTli/tKziWH0ScFAOCA8ijWn9gQkD3IqA8tDiPB97DWt8ITUqp80wyN AQCm0R/FDwdgM7IHGfWhxWEkM30pMu0blGCWeFIeK4CT5E655KnLAdiI7 EFGfWixl4qEL62Tf50WUhxD8lcA2J3pTOMAbET2IKM+tDiMlJK t9vz2+huMHN60YABgNJrsmcgeZNSHFocRAMA5muyZyB5k1IcWh xEAwDma7JnIHmTUhxaHEQDAOZrsmcgeZNSHFocRAMA5muyZyB5 k1IcWhxEAwDma7JnIHmTUhxaHEQDAOZrsmcgeZNSHFocRAMA5m uyZyB5k1IcWh1GM/2vTAOAKTfZMZA8y6kOLwyj2+6/V4QDA7WiyZyJ7kFEfWhxGgW9C6LMBwAOa7JnIHmTUhxaHUeCXs jooALgaTfZMZA8y6kOLwygQZIP8AMByNNkzkT3IqA8tDqMA32Q DgDc02TORPcioDy0Oo8C/bHzba/IDAGvRZM9E9iCjPrQ4jL7ir675MhsAlqPJnonsQUZ9aHEYPZn/RERvdfgAcDia7JnIHmTUh9blh1HcLsfZ+P6JzhsA5vPWZJ997J +0FoxAfWgddjTo5Q7H4BNlfmi4AWAcmuyZTloLRqA+tA47GpSE Y7FXo0zPDQC9+Gyyh06x0MFLQxfUh9bZJ0Ws2Ozm2u6O89JtA4 AJTfZMBy8NXVAfWmefFAFNdzvh62cabgAw8dlkn3qGH7YcdEd9 aJ13OiTpj8L4mqH5OfukBoAu/DfZJ53eJ60FI1AfWocdDUnWE3DJ0XnweQ0AjXw22TNnnOmktWA E6kPrsKMhVt2zvnclv7GQdQn4+EcDAEremuzlMw510lowAvWhd djREGhsVSva614tct/GHQC25qrJjo/lw07pk9aCEagPrcOOhq/q9rS9u6XbBoCOXDXZwRTnHc4nrQUjUB9ahx0Nr7pTL9fLxp2uQ DNgy4pOfWQAkOOzyT71TD5sOeiO+tA68nSoW1R8XJp666TGkJR xAsDZvDXZkyea7MhFoSPqQ+u8M6J6Rbn2+lF3ycJd4/rswx4fAMR8NtnAndhdWocdRh077NyYv4z4guD2ET0xrTaAG9Bk A36wu7ROOozq1hL0qXFPLPTfyanjG5Nj1q6yvAThQwDYUUWTPc jQZQJbYBtoHXNqVJyAydMz92vulvjwzV2fm7Hv8n+ptr7XLACw hOko49wDhmJ3aZ1xGFW31/EIuT8JjXLy4uQnxYsbJQM74xEDuBlNNuAHu0vrgMPI1KrmLv5+ GFyT7L+Lnbc8VG7qLpKtfMfxAWAymuyZyB5k1IfW7odRRYetGS fXNOf+Gje1xYZbH5tVMuAuI7dH8kT5WRIYgL04bLIPPsoOWw66 oz60dj8d2jvs4JSU2+XiXMUOWxih17NIhj35KefmTeZkZmAAdm Q6K+YcLN+3xmFH2UlrwQjUh9a+R4PpXEte+R1Bbv5ybatAmEUI u8vjiAeZ/5S/S3YVGIAdmc6KCQdL8pwfOuNMJ60FI1AfWvseDXK3Gl8s357rjI Ub5d46OUjcbWtCtdLENo38HlobG4BdmA6KCafK2QfXwUtDF9SH 1qYnhbU5S/Z28ifBRMoZ5YuDDzXXVMg12Use9IT1AjiezyZ77ekKrEK5a+14 OljbR2Vr2zK7Mo3xZY3BmGZZ8qxpsgG0c9Vkxycq5xiuQq1r7X g0WHvcvk12i5lNtqBl8IpggsCS0c4MCcB2fDbZ02YEXKHWtbY7 Gr6nm6nPTv4cDDsi4FwYwoddmuzkJ96a7O3KD8ASrprseAqOMl yFWtfa7mjI9YuNTbbweUeaJrv9icT/9oj/WdIyvjWYOLDgk2nB4Gy5yi9aHTjKTE9qwmPlKMPNqHWtvY6GuF lUviy/f81dOToVwrzCr10mipc/7aEnI6G/Qbty79xg9eIQMj2XCQ/x7LI5aS0YgfrQ2utoeKOteDX+Sk22/KdG8qR9AygmZ+ZDjyc69bWEaXIVbi2qXuNggoonOzSe5+ij7LD loDvqQ2uv0+GNtq5x/Kn77L45KU5XvKxlunjYvR468M+cPphu2yeHTfYz5n3hwXkrQl/Uh9ZGB0Tcj1a8C9/L5Iu7vF81g8Qrqp4uN/Uv1WHv8tCBZ91XhnTbfvhssk9F9iCjPrQ2Ooy6NNnxvaaL5evr Ln5mPYV4xhFGrwL38FNafiK5linzPKZGZA8y6kNro8PoG2rybW c9gk1vzb6N5vfKCY8gCMy0lr4LB5Qc1hXVvpAp5zygRmQPMupD a6PDSNMm1o0588U5ecbkLBs9dFzIeSPrPLxT0WTPRPYgoz60Nj qMkk128q91I49rf0ePX5w3+fno2YEKu7SwWwR5EprsmcgeZNSH wS7bKdlk921bc8Mqp2i8vSNhusmvH2G6XQoP0+zVue4V7e5Mqe a5NCJ7kFEfBrtsp+8rLX69jThVNU2zn8b6KX0LOD+k3HTzM4Mt bFcVVPI0pjzzUBqRPcioD4NdttP3feaqnfXwopVjWJ6i5cHAv7 4lkTsiuhcelTyHKc88lEZkDzLqw2CX7RS8IINj9M5TVdM3rGpq f5n/2ynvJxc+Lwh6lah+R/QK6c7DZzKa7JnIHmTUh8Eu2yloFkd/QeWZcskeMiPMfs/zgkbHJnvaXCNGQxJN9kxkDzLqw2CX7XRnP/0yLd9PonIxeIgNfgT1UF0b+rqqq8DkXRTzBDTZM5E9yKgPg122 03tu+ukgJ6jurZ0kR4jESYTwQGiyrXVi2inyNR1nRCOa7JnIHm TUh8Eu2yl+DTvsKdtVrMtzKmiyoWFtoYpDCVXXfZt423RHosme iexBRn0Y7LKdcq/GuMV02GsKqsPeYr002dDoW8PCmVCcSI5BOIK6RI6cirNxaDxnI 3uQUR8GG20n/dFZ936doD0kbyuSCeF5DhuTJStZUyFygU3YLP734BlMSeaJNCJ 7kFEfBhttp/b3Wb7x7vA+HjGmMHLFOPMJoW60CoymKeyF1SLXMJU8gSnJPJFG ZA8y6sNgr+00rtFUtsh6g0JqH3ayHWPGZG9tK4vcQ1FZY0YLU5 J5Io3IHmTUh8GO22loa7vQkYsCioI6X1v2xam/G5MdOgdN9kxkDzLqw2Dr7SR021ucs/tGDvSV7LNNfVXHSOS/fgNjt85Bkz0T2YOM+jA4aTsVe+6FvayfSACHkhvB1e6Ig3EV3t losmcie5BRHwYHb6eKnru6Ax4xJsbpWBs8zV5yyaxIsjBO/KEyqp/jfwAcz5RqnksjsgcZ9WFw4Xbq3V+VrV7x1eY/bh56NTl709JbfJQ85clM2ebRNCJ7kFEfBmwnPc7uLazqfem5u9 AkrXuG9aPxTJegyZ6J7EFGfRiwnXAAn92tw5C2YM2V8PRNugeG Xkw55wE1InuQUR8GbCdsarsWdq9ol3OVKD+R3IkmeyayBxn1Yc B2wl46tqq5Nr2o+xIaBzzY2lzxmJww5Z+H1YjsQUZ9GLCdsIu6 fqu6k67QvqiKES7RMefLZ4GV6SnwyFqQPRRRHwZsp6IJnRZkpg zPfEa9ZqGK9Ho93Jl1gkYVT3ZoPAcjeyiiPgzYTgHNq9dq9Zp2 pU+jq8y3ROIh/l007kpXNQNZxSYaGs/ZyB5k1IcB2+lp+L9NkbuAV3gjZdKcZ7ilBnyuyI+KwiimlGy7Z Xo0PMdGZA8y6sPg5u3U0p9Zb/TcC7qiSdGmmayogR2XOcc3J72SQ57dosmeiexBRn0YXLidevW7 dbfTbecUc3JS3kxrOWPJfQVNtjI58i0k2S2a7GnIHoqoD4Pbtl Njl5a8vUu3XRHMSe5pr7/06zpy+S2CPOjTGN+V+xV+0GTPRPYgoz4M7tlO8Wu4+Fb+ZbRfL ER1ISEDl+RHWTM3pEJJUzDJzVgstuGhw870aHiOLcgeiqgPg0u 2U/xmzbU1ynbHNGlxqF4z7qjY9NyTFk3BXJUQgTIP38a6y4BYgiZ7 GrKHIurD4IbtlHx9xt3MuLestdXuHoBbtNdJ8vJvzsxXrzxcXm xboMmeZpfs/SKrI7oIuTY4vjTlHfgr/U+QhwYTnxFXnRc0kTL67Fj8Zq17y8rjXJhY50wPhSfYYovs5d6 ka6O6B4k2OLsuNXtv/uZ8Z0y+1y85LHKPhuPyS8jGbYmSW+Fcr6whDLJioUgwPQ6eXYs tshcHuUXYxyDRBmfXZXHjVezM4qvaFFjy3hvOC2Hhx6/dRMjJJbnKNcTFiwXCvfEgIxYFE9OD4Kk12jF7PPSZSLTB2XUpb zzltlS+tk0v5i6B7SuXpeMXXkdO19kZS+6p768dl5+c5fgMb8H 0FHhkjbbLHvt0MhJtcHBdtjSyhm5awRrA8edFcoHHr7pFrpaOT 1px1R3fr/E4xV2MOUyPgOfVYq/ssUOXINfeaXrQXrOY/qpvkfUBCKPJ4VXP61wuqxyUslxBHpw3fano96y8H4XpTk3yFkz 552G12Ct7vV7WMCHRrn33w9C9IY8c/HXoXs0Nrg/vJMmlHbzejq5KXXH/CncVWWc8Ncm7MOWfh9Vi0+xtGvamSLRrye52wkS5v47rrXOTfq cuhneeqzrFvpKFemrqlPt33HRzjilo0GRPs0X2cseg/8jPQJZdSzbZI/aG3I78/qv77MXAJvcQfuSa7CXBbOeef6JoVtRl4cpD4LwMb4Qme5otshf sWTrsyUi0a6ua7LirXrgz5anPPjJoslska+PIalGuKNjUpvFzy WyJByPQZE+zS/Z+KauDugWJ1lpSl8m98Yv+SdpRsNjkdEsyIF8wM6SZkqtrX++I yllSHkVxSA6DbFSxoi6P9fvh8UneiCn5PKkWe2Vvr2iPQca1Vh Vo8J77hlHxptS/SuNPch/OWbh8zYR4lkiuzrrexkpoH9C87H7iAJaH1F2XPDc+teOTvBFT8 nlSLcgeiqgPAw/baVAM72FRHH9C/6ScwkkbN1RydcUle+h3hRjmhyF/sjtvG8FVMBcyJZ8n1UI+5dZanRv8D09Ca0nhBpMOjeEdXDPLiC 1tOjJM0W4tXmAyJ86P2lXh5RI1et6ZvnthdSzuOv4LmZLPk2rh M3s+o7oWT8JgfuF+X1ejX13fwfUT5Zqn4u2aG3PdQ5AT0zK3k1 xjsjA2ykZFwbRMJH+yu7qdWxwz+bPwYVyT7WGggin5PKkWZA9F 1Id3M1uo+G1tmjHZOSnJAyY/mZOT5ZLLVCawbqKWR9Zl3l4jP/c12c+ifZGMYWYAeJmSz5NqQfZQRH3gP4I3dHXrE9zYeBLFYSzp JFZJrv39uWKcCVqW2TJIPKDmw60Jyxy90tws5yV5I6bk86Ra7J i9OScDXiQaoeQmNLU+vbql5Agdm7CNvOtNZkO+S9A9wi4T9a0f +ZMD6Gug43TymEfmeQvWZz3iKLjHdqkbdPhDQKKRIGxFZffTq8 HqNewB3lW/a1c+o1UZaw+jJX4hM6Zx/FMuqvpZVNx4ZJ7datllHg6Kfe2VLp7yEiRa68K6LG7I5AHdeL4 nb+d0ePL/zUzuGm+J6lUqpuuLHx7gXZR1abkN2F5FR+bZm9zDqt5ZXR79VT bK0jfUjcI+AIk2uLMu9ceu8p1tOso59P+Rs2dKqQd1AVtrJvl5 fdBeeVjXL/XvmVXBHE/eO6bkCyPscpgstFF+gpfF6nAuQq61Li/NuCsalJBpE+3lm4QgJ1tnqeJBy9dbPz/AknX9oq46+PXIVHtQ3Cym5BfH4VEKdklO/L5YG89VyLUWpflP3BU1nsXdBzyP5kU4OaTurI8+eaVw7xlZSpq wtHh8ecaDs72WZneYkq8cjaeZtEVmkofkwnhuQ661KM2X3BZ3t HqhXuSycWSW9DWgL5sjE/V6V+dnmX4iOYkyq6bkay7mQM7ZIi28Ydciy1oU5Zemp9EQ7pq1 FO/kJM+PZxplPRSvuSRRcyZq+RAt9E/ZVA/KizmWk3bMCS/ZyciyFkUZK/bNE0Y43rVN9j9ybdBhP6ub7MYrobS2ybYOe4kdc7JjzFsj11qU piDZK1utXoRTueRclbS4VIqVc09dOVymt3gOYHrKpiuVFzsss+ V2zMmOMW+NXGtRmhr01t3RZL/09XNVdTlcqbd4DmBtsjXXWyuHxxpwuPXgDfWhxXbCEjTZ//z++wW2fOVVyfku1smqnYRxkoqGOPdv0brvOK7aU0rkBEXUhxbb CUvITfYNNan56jp55Q3JeVweTUviOfu5Vy8t3hQt41jvOhs5QR H1ocV2kuWOcqXV4buWS9HZ2bNWSHDl2cn5crjMyfHccKQsXNrB WW1ETlBEfWixnf7Rds09rF6rF0I2zstVRRnkLj4vOUkO1zg5ni ADRz73d0WTl/ZN5mEpbXdemaE76sPgwu3U3grrL9bMdeEj+EdY+xn5qXjQmlt2 T4uGwwVOjifOgMOcNPpW8pyqDmY5L6XtyAmKqA+DG7ZTl+5WGK RiwC6D7K643h3T0qskgg9zF/cM3ZO1q8vlfH4Mv6PbQaHg+y522kQHICEookQMTt1Rca/T0vG0mBDtvjQr9Z+Wxmcn3yh/3hq6V9/VOVmmare3kWdcsuqh3nXFa2xfu5DeYN7mdRyFhKCIEjE4bEdpX l36G+uOYGGolmCsYexiu8z0KhX9vbkLDi4Mh0sbGlI8+LcwTj0 EgnXllinsOJkwjjDd5UgIiigRg2N2lHy8Ku8akQ3lC2BhhMt1S UtLkqvHr5uiYoTklceXxOoo/mNyPEEGjnzW74q+S9NvDetldbPchpygiPow2H07VfcrFYdsfGP StNmVN+6icWnKp9Oi1+rqRkve1R6YTw7XNTmeOAMOc9Lou6J4X 1RvGXnz9t3X5yEhKKJEDDbdUdaDMnnsVt/1S738TFNUBJO7V3nXFkYsTX4637lGJLPlQeeGKn54gJmLUk40O clBBi55yrl6Vu5iYZfFfzp17zQiISiiRAy221GmfkV5/grXj47WFJ5p5K1tvbrqZ6ocWfPh7hwuan48g6rID+Wp2Dh+MM7 31yOz2oiEoIgSMdhrR+lP3uDK4l2j32Ty+KZQ9cPuLmwxHC8zG eqIaJPDes5MHScr+sawKh4nqRjBepJrjtDixd8PD85tNRKCIkr EYJcdpW9c4svkG5V/rWCazhp2LsjixTsyZXhhPBOiEopn6LyTvSvyszQnYZyk7uF23H p+qssPEoIiSsTA/47Sn6HJy4R7c3+SW6hcGKa75HmV8QsBFC/eVzHPHTMwcy5rVPInu5u8IuX+mhDJbdaW7nkbpx0JQRElYuB/RylbmeRlwr3y9Y1dVHGc3MjCh8o+4JLXRi7DRR1Hm7zkIFrNh/uavBzl5poQyW0W1u3yjewTCUERJWLgfEdpzkHhGv3nQ1uo5Mh1 MRcDu/bNITfEjVYv7j+SITmMs4XD5XiL5xhLnrXb3b0cCUERJWLgdkcp T0Dhmtyfvp9P7qWCuYRuSV5US1qwu7VN9rRZRk+UzKHpenQxv9 +dfOzvhYSgiBIx8LmjurSSci+y8JAN+uzcBcUR9LPgMPGTnfOs pxXVd5ZVNRxneEkYx/tF5kz08GVECglBESVi4HNH9eoycx8u7LDfMIQ+W99Dt1+DHSWf 7OjHPXPXjJilcUC20iDBP6hGlFly2LWvALdICIooEQOHO6rXwZ drsp2crUIkyvDos6+1qsmeMMvjtfvxc3QcJk7pL8M0YHEEHmUS OUERJWLgbUd1fI3JTXb7+O1ykegjVDbZTtaLXpY02RNmqWuqJq hu+FAk51PomJWKI49Z1q5ICIooEQNXO6rvqZccx9Wpmgumb5Cu lowuks+0vR3RdCeDyimYd3LRFuf6xlNMEUysmbRWbMepb0BCUE SJGLjaUX2PvORoft6OQiQj8uBhyehFru1e9FN3Wc535ODnvtMl A5A/iVfNtuplYRp5gjESgiJKxMDVjup75OXegh7ejkIMI8Jbvl70JR T2kqnbByw2tWu5PUkOsLbJXjKvZ+QERZSIgZ8dNeLlnRt24dvx 9yFf0H3SjgNirWOabPlfwr1maTfzn8S3ocl2hZygiBIx0OyoX8 qISAZ1lnKfPe1MUbbX788jZu87JlbJlfSqqVuGEprXLrN0ody2 qLC2yebZBUgIiigRg4Ob7KfUZz9TWm1l6oZ22A+vk7Oc1GQLf0 3+XD1Xy5XFUNlc1WiyXSEhKKJEDCp21EZN9vNZoNDjdv8nRDyg PGbQYW+UXiwRP80dn6++yV6OJnscmmxXSAiKKBGD45vsJ/pKTJgo2Rw3kgMLrhmaBE7PMyQf5Y7PNxlwsB0mhpOl3MjT4jnM wuzx4GIkBEWUiIF1R+3YBeZ6WXnGQY11LqRn8InP6+QYVzXZy3 eE/rIeQd1oYenuuGtGIyEookQMrDtqdCs8YmRhfGtz3B6A0F7PX/7Wiv/UqbB6TWVyGS8JqY4+4IVLMwU5OphTbfF870FCUESJGFh3lPyOd 97lCLOMCEY54JyDfs4s43SsMavVS/+TC8lbnBq5mHMfTl6jkOrcxVPiOtDC7PHgYiQERZSIgWlHCUfS +/n3guBDJw2NcjpNtC3LaV+16cZp6e1lYZ20PNYJgek/96wimRPyX/eUd8y/Hwuzx1OLkRMUUSIGft4lFYPH15sGWdI2dZm0Lle7nJ5+mtqv5Q 33SR3207YR+j6CxtFcVemOFmaPBxcjISiiRAysLenQSN7xlRPF IdW98Ia2Td3bspZWoHHq0YY+iI7iZzpzdyQjGTf1IN/Iq+OveAp9n90uFevZwtTxyGLkBEWUiIF+R81sI0xzJS9uee3lX sMz39+5exsHrLhxjq07lS5PvDi+9U/OBbnquBBh/9bNokn+vg9iuYWp46nFSAiKKBEDVzvqG4zp+JNb0vaTtPjaHjF R7k8tI7fENkiv1OXGHPewNPP2GlOern2W+eIs5dbic4GayKGxM Hs8tRg5QRElYuBqRwWnrfXwFXqOoa1Vo2JsdWE3JnOO6icSt7M jtK+rZSj53vYg10rmZ0iSue0AACAASURBVItF5WJ2HrZbC1PHI 4uRExRRIgaudlR82lacv8UXXq9GqoWyCasOMrjLZxNgjSpOmjK NC8evvn1QYfjxxh+vZeHq5HmFUHd/HAstTB2PLEZOUESJGHjbUfGBW/cCU97VsZ2yTqG8pXpG+ZPlrHlY2Mp0CaPj01+Vh76CVcSL0uRB +WGvUJPb6vf5p0L3qW+wMHU8shg5QRElYuBtR+UO3LqDuKKtGa RvwMXbix+uVQypOoET9Hq+8V2aMR0mpFqwEE1ags/rZjGFpwnppIcy38LU8chi5ARFlIiBwx1V7DCqxyy+MitGbqdpr fTj6D9fSNNEeos5p+LxJW/RDLJXZoqSy5HXOLQ8fhFlAIc9l8kWpo5HFiMnKKJEDHzuqKFvW c2rdKjuARR7gsbxu0tGtfCJdGF9rPH18i1bJycpt/DGHGqG1Vxvjda4evzPwuzx1GLkBEWUiIHPHVV8b+lfw/q59K9bP+PLo/l8/SdD8hlqnfa+re6y7bwrkkvCuvDcjqsbUL7x1Ecz08Ls8dRi5AR FlIiB2x2lfHUNesMp39Md3+XVEVZfsIrQqawKaRChEvQVcmpyn v9WgrDGmdvKNGMQ/9CQDrawvHlqMXKCIkrEwPOOohFJ0izWc0JyHeeqeEYLyriiqo9 PTu7X3PUjGu7kyLnBkw+0SxgXWpg9nlqMnKCIEjHwv6NM77BT+ 5KKzmxOYBXi8PzH3M7UF55axrF4mdX7vZfcRHLADTm43cIE8uB i5ARFlIjBFjuqoueouMUh6yq2WHIyQv9hV9P0cLmLT83JV3Kl1 cvPdM5p7aFe8oyGWphDnl2MnKCIEjHYaEdVvx036lqq+4BdFvj k36m7xK9kfY7x9YclRJZc7LSqTk4tx3DV0xlqYRp5fDFygiJKx GCvHVXXgAojLF9+HI81JD9r0ctFu91CYnVPk07uERc7es8WJ9W HCquFmeQJxsgJiigRg013VK83brLHHfci7zvR0GiHUrZT8wOrV vdYlbfsmJA6pmz0TYty2E3r07OFyeQhxsgJiigRg6131Ih3bXL kLgbF1mvYyeTg/a+x8RHHN8qDeE5Fd9asqregJDlsdUjQW5hSHmWMnKCIEjE4YEd p3pcHOG+ZxVV4W7K+P1MOovk8vqB+AVuZ+eiTU/z++4+fq5I/08LE8kBj5ARFlIjBSTvKW0/WRXtX55Z+OZnmdkbj1Wtq5e3yNYcVgOxd6YhHLwwiPPFLMj/HzL0sxLBkXs/ICYooEYMjd9SIt/JMwmv+MNbV5TLTkqLimH0HN91l+tNh4mX2fTSaYb8jX5L2cbpv ri4hNd5+XlUcthyMQIkYHLyjXJ3mGtsF3EXdSuUXdkdd1lUxlH BXY2C7EJZZ/eBanvslaR+h+nnNCaz6xuXxj3DSWjAIJWJwyY7ydrj7D2ym9lV r3uKyEWtpHFkY4YYK0a+x/ennJvrxTXYDZbYXJlZZBsItT4/jy5UzVoGhKBGDO3dU9Ut3oxm3s3U2Bj1NYbQds2TybWIWxhDHA 4H+cPOw3ysO5NwFy9fSy+7xYwJKxIAd9Uz8bw8Cq9ft0UZZmvN McyP7z08jb6vzFo83mu3g7TD85RvlZGzfX4ULtq6TrYPHHJSIA TtKJrwVlFavYFfekrnwEecmWp6Tobytzls8TsjbQbNZFibWFLm 8DX9i872RTcPGTJSIATsKzilfdXMmXfX6dNigjLZ2ableakkwb imbVM0gI8OUpv7GUFxILs74r6sOinY7xozJKBEDdhQ2Uux9B1m 97ufJ9CJ+wuvuXdrQBf6ixqgYD56u/2nywsQm500uQRNkcNemBbNjzJiMEjFgR2FftT2zZPWasnIROg+ 7mrd1eYtnIaEN1afIw76T5607HN4r/R8pSdsFjPkoEQN2FLALmuyFvMWzRGN7nWxb3TbZ7zXCvkuOQJO Ns1EiBuwoYCP39NlxJzc/ACGeCwVdo6aJTHbVyWuGRFxSjK14S/JemmycjRIxYEcBG7m2yZ42ae7n8zJsZeqw9c3r2ib7G4McsNxV B8mJP9zFdgFjPkrEgB0FbER4x68KaRwn69q0W+or7rCFy0zp8t BkB8HETbNmXe9fczdWJGc+z7HBCUrEgB1V7ft1xepYcJFkyR1Z h0JHMm29/ruiOeIOMnlBRaJcNdnfP1V0xkGWhCbbbV05DAneUCIG7KiA5lh ssXp92F6ykE6tLv3GUV4TXCbcxbb9evOQq73qLC3McHHeuhoon vmeXw1+IoFblIjBzTtK1xWbD8ERYwKvZOUcXE7K/dJx+WzS2JuKb0K6pGhhkosVlVy1cmTlurxVmpMw4BklYnDVjmp seYu3K5PZPgJulqyT44tnwjZhMwrehLxpaUmRk1TL834DqwgyW J28ZD8l5yEGOEeJGNywo0ztbO7iLqwzjswKdpWsjXsKpu82Yd8 pvZlpTFR8+8KcC2uJP6yIM1dayUmd1J6HGOAcJWJw6o5SvjsrX rHfC0zZGxcSrqLsCY6X3CktVi/ItTdFdbnK5Xlt8n/5rje3yyqmyC1QM+N8HmKAc5SIwWE7qvjibH+zdnwxV0R72PNCB aFUlsTjRHKzCFbHu5nq1CkPt36R2mKTQ4ovqJtFWYceKnN5APC PEjE4ZkfJR7aHA11mit/nEjCHUCFL4sEN6g4f+TQTrpmjGF5wQXWo8QEeD+XkbF8eAPyjR Ax231GaM8vDyWUih73vutCF0BksiQc3qDhwlH3kwtJNnqVBPLm fKyYyhbHK8gDgHyVisPWO0rTXwr0TwmsfIbcQV+fyKr9OVq/DRqiHJfHgeBU7JbheGGFh6SYj/OX/DVAdp7DG76QedvHyAOAfJWKw444SOqRN26YioSPct1msIDTKQR LkROnH8UYugyUh4XjW6gquL96+qnR/itfH+4kpCcFJEvyQO2o87OLlAcA/SsRgrx0ltEFyb+Th8GonN1hnrDEp+WbqvtjcLK4SmwvGT4Q4TE X9WxvHVdWbfInE1/xS/0uQxZGTZ4hwnjg5apYHAP8oEYONdpTcYi4JqS/lKuQ8nJSN5Z1uut1el+HjtwAcqqiu93rlvQs31PdneXPpg/yOozw0/BzdHmKAc5SIwRY7ytRbeFjRhKi+OdG8KjbioZ1NWt5t52b0lig co660vi2m6fqZgqXJm8vaYb8nc/CDcL2TXewhBjhHiRj431HJ08fPkVStS/DJJOybHFcvG9n8bjs30S4Zw46qm+xf9O9/+XpzZD18/zHQZXMlO+yndFC72sJOwoBnlIiB5x2VO338nEd9Nb7P4g/3StR2Ab8mvCmFwTdNGrZQXV2mPntJAeub4Ioxg3uDceLjws8ud hIGPKNEDDzvKOHg+/46N6g1ikewJldu7fhPgtgv0n3k3J96TQQEGpts5e1rm+y+HXY8 ZrKf/v33XyB+NrKTMOAZJWLgc0flDriFZ3GF+XHmIp8ciUl1kNXPZfQ j6zumPI7/54uttRSYfhcsqeE3sCDCis0bXJ8cMPen5OcLOQkDnlEiBj53VP LEmRZqSxPWcq81yOTUT+pM9/mUn4b/5LExw/I4vZ5a+zjy7Z6fLM4wZxcsKeM4sMbD5Ptr8q/JPyXvWshJGPCMEjFwuKOSx9zoM6hja7Vk/O8suakHTVpNH9gvMiewLvNWjyDf4vax4jBdykxTzI1TVIfUsse Du+IRgr8m/+RqI/uJBG5RIgYOd5R8To2YyzR+7mjWD6K8vm7JybtcHeL/KDPQ8v7rpeVZ5wbRXyxfYIoBqNCr0nJbYFUxtx8vwY3xIPEF8V +TNy7kJxK4RYkYeNtRyeNGE2R101O8oAt5fFPkmqXlpus7UQtT 8mcGVqR5uMrbrX8NrjGHDliM2IamQ3KELvMGtyeHCj5MXpC7dy E/kcAtSsTA247KHVWaG/XjF/ub9oNYP1T3Q/Z7rAez9JqikRBMS87nq66T+BblOBslB7t7K23ErowLfkRh54/h1v81iV++e35S+1RzjQfe4oFDlIiBqx2VO636jv9LNfFdzl/N1LlZOs6bHMfVaZ4LZugjGKqifpIlId+7aXKwqaDeBpVfbiOY9 lSXQfRTBJ/krgw+FIbyw2FI8IYSMXC1o95D5yd+AZD7UDn499clh11u6l5hC Od+++Bd5IJxFWQda1HpL3b7VsapcmfU6DqMT8g6g+L5fihcHH/4+G6v/3EbGPygRAxc7ajvSfT9MPmzddhf6j2xdvn6g7tiWP3n8yUj8RN eO02N6YvQQ63iTt/W8PvhJQWZ3MjC8nOb+heZEX0Vz7HBCUrEwNWOek+fX3NjHY/5WNqamYKo2sOTXwAtI/eSjMRPeB3Fb1bru9ZhxeIeuXNpl5axTq4nltcrJGSjXPmPEMtR IgaudtT3QP9+2D7g4/6Yi/uw4K+moYQpWoLsJReJnwg7il/YymU6r1jcQG4xrSXtX25FxTUGB3j8p2eT881/hFiOEjFwtaOSh1TyYFKGHZxurhYbE47p5MX6P3k74nORbPGYKl h7kfN6F+zrW4RxWf5S1gVbI7mE4MUhrCt5S3xB8k8O+Y8Qy1Ei Bq521Pcwij+sG/DZqnXr8qKK73V4xOeC2ehhFdU1H11qAOglrsZkfVaUugfCJtUs J74md/w+zk7gHP8RYjlKxMC0o0afoe/I8fFdPdq+h37L7clPXOVBCGbHp/YlvLb1Nz5n/XsDW0uWovyh510sB6mMPHdZfNePJhtnoUQM6jqAQYfFt71Ifl4 x2hbnWqA65uSN36z6SUXx0Th/T8daNkjxfT8gXsAgV4rFz11tZCEeU5y5K+VPli9fY4sgsRYlYq DcUcnzaEQwv8x/kVwRgJNjvUJ12Mm7vke8q2xoHpC3l/RXooMwRqi50eHCcSehFOVKzu2UyYWdnNEUSTHy5NqFvzq0RZBY ixIxUO6o4EwZdDi+w+ZO6ooB+0Q2V116hddby7BDKV9vy1/PchjVD0s5wqr1AoFixRareuFe/k5UMbXmlvhPP8fHb9IWQWItSsSgbkcNOi+CQzB5QfWAu0ie48o +LPm5fpAlrG+73Eu64wt73BS5QYrD9loa0Ei5C/RbZk5hf2cxzajf+PEF1ZMutEWQWIsSMajYUcnjptCSWMixJY+q 3Cp2OddemqM8eYvmT56zUbHw4Maheq2u+LA0FzQGA7Sz7g55Z0 0o7HcK5VwVh8Av32Hr511uiyCxFiViYN1RQ9/0ylPJFMAuR9uTym0x8mJPprzYA+tr2zSgUpd5hQD0twh/7RskUK16+wR3jS7sYC5lYBWL0v/q1i5xYiFKxKDuZBwXTHwwJaczRTI67HYVZ3pFN+Y8Cf9Uv+H8a HlPP/TZ2E1jY/ob0GfHIQmz5C6umDH3yUbbdpc4sRAlYqDfURP6HuEEbAxpQvDV Kk52+Xr5RdIU6yzt77zJuryn49GEv1YPDoxQvQV+n/Z3hDhIIWB92MlVJCeKf/VslzixECVioNxR8ekzYivmTiL5hFKejI1naHd1x3rx+rocutXr Fdhdx9ezPL7pT8Byua2Rq1j5NEsOKN8lR5Ub8HuZaeTkKuJfd9 mwu8SJhSgRA+WOGt1SfGex/imIUDPF2iOvIoea6+ULNjrlk3IVOGdRwuzjAhDG3/1p4hLyxhm3iapnrIskHjD+dZcNu0ucWIgSMfC2o4LDyHpUKY/s0Ue8ZkblpKYVNQ6yEc1LNM72m4GK24OhZi7T+ifAocZN104ZY d3S5HHqhgV8opoNvG3+4oGoOTH1B2vdWaxUfdY/VUsoXmMIfTfF92sLD0vTfw5swduebdlQP7HJZqviMFSzgcPNrz mSlIep/uQdeeBrT1jrLfKV7+f6AOBQ7imbSgtwyEkBN26l+N74Vw/LBHqhmg18bv7isRVcaWpJlbfoG2jryMIs1lv0F+tDgje5J8iTx daqj01Xs/9KLTX7FIehmg3cbn7TwWQ9KFva4hYdO3LT9bXxwoXcc+ThYndv Dc88rIKDtHHSuKVOTtcyxUwbhYpVKBEDzzsqdzYJMVef1Mn2V9 8QK29vD0y+LHmjdUY4JOwFHjH2FR9TLaelZqLkdI3DBp/E11SPP99e0WIJSsTA847KnbbFmPse04rOOdR90urb2yOBB7mny VPG7uTarjsJlSdz+/YJRogH3G6H7hUtlqBEDPzvqMZ+sXv7O05FqLnXhv/FwmpQlwAspzyycq2zpp8WhmqMXPj12XCH7hUtlqBEDLbYUb1OQ +tBPFTduyEeJDlm10jhQvLJ8rixu/lncq8Z49sP2KF7RYslKBGDXXZU7kzsckqOPuVz/XTFXLlbJr+lMF/u4fLQsbtvDc85h+N56waMx09OWj3FfHtFiyUoEYO9dtToVlLoh rvoEqEQc/v4cCv3iHn02F1cw71OTnmcxinimJPjV4wMb3iUXyTCYMe60Z+/O67uVQye9voqNNk4lVDDme8rDDTzVhyk8fU02WdoLKob3L5+k3 3LpaXo9131s9X/Kic6yj1uygC7qzvD21ufZKOsHCp5Y91QcKLYVfPm/efqxVvtXivt5+wIIyLxuVJMQ5ONU62q4eS8yjM2bqlz43QJFaP leutcn7002MWuXrzVMbXSqwcV7s21OHUTmeKhtwZNNk7lqskO/qo89nNNdnuQk+0Yczvhn1tP9BbOXX+Pe1de4bxCGdeVTmuy4yW c95hgRZONU/lssr/XBJfFv9Jk70t4UnGfXbzlBveuvMLBhZJsVX2uNxeqz2ixBE02T uW5yf5e+W25gr+2DO7KjjE3kp9U0Gcr7zrbpcuuc0mVCF3swsP dTzynkvOstHoR/5MLxk+EQIXl57D1+p/6a+wd9+aOMbf4Pqbksf/+mvv8Qpcuu86dVTKhwZowBf7Rp7q7+WtMfj4tDKCjVbspCMB6i 2aQhYtqtGPMLZKnevDsfv/twuOfb3PpsutcWyWxhl7LYPUqT7AqyQufbG4Kigqb8nAwmqYW9 mDjyK5sGna1XB1+f31/nnzsu3XpsutcWyUV5B7r5i03h8OEzykDYVgPSQCsgpJeWMPKHW TagFvvyn0jtyoe2nGJBtffk6vApcuuc22VYAsOG2vBoGjld4Dn hACxuMOeX8bfPqk4tXCNvvPexb6R6ynP57jJfoyVc6pLl13n2i qBcxv11km94hdu3zEtuFxcz5NblmSLX7ze9KetN+a+kWuYDmSa 7JxLl13n2iqBW1v31knVDXexwz4jP7hH3GEH7cugqs4NLsxVbK/P67CfQ1uCluM3+Pmwd1Ode1de4eZCgTfdz6+4u602Ih7lxcJfu 0QFTBPXbfxrx90nD1K3v+SQdt+YWwcfqy6k4Pr3175vhE1dvXi ry2sFfrQcXskXc860ofSzCNfIt1cHACwR161cycod973AdIs8l P4uzV+3sHv8r+qDOnnjt7Q6B7ohUmBAxWC5utPwlzcn1PZJcyN U9weAc8nS1dSzsPWsm1G4TB6hOPgBG3P3+J/e7XXwp35hbowsGFA0WMt0eFW8UEere823jOBh1UCFtU1McXPV/cl0jX/7LqHXCSxf0ynYvZEFA4oGa+kPr5ZGdjRTl9xyu8O1A0pyeQ/d2sqdJd+umaIpSgc2XcLQs5dTN0AiDKgbLKQ5vKpPz4WUHXPur uoLAM++Bayp88aNrx9BuEAZwDF7c68ltBRJ8sbgw8YKPBW5MKB 0sIp8eHV5yy6nX0X7BYBzyfZFeYtG7hZlSLm/6pemudK5XVahfL4V9wqlhX9IhwHVg1WK77aTTjfh1G5vBYAt1B W/ZsCKrqh4pT6wk7an/1VUvx3om3shdwaUGpbQdNiTQ5qjoic4OyG4SrKSZ7Y+mrlMkRy 2Pd0upKVFprfuiyQaUHNYInfeXXIU6g/9SxKCS2j+dd295k0j39xhPy5bgpbCoL0egVQaUHmYL3fqXXIUV nTYvCdwBmUZx5VfvWVMe8e0y47cla6Wk3yCFWUwPtK7kFAD6g/z5Q6+Gw5E/bmffLUcnx+crbqMhe65rp9Ojl8RTMVcnjlZkdxbC0Ee/Gj8ILMGFCLmu7DJNh398ZXtPQTggcNKtgbjKvju1q4rLo9kb53 M/y8yM/KrkFkDChHzCSfgeYdjXXsdd9jxz8B2vBUzHXZg1dLiFjmuk1zn LdyCEcisAYWI+YpN9hllWd1eBzfmGm5gR0EBL9nypr0Z3DI0sO XmL7DYW3+jyvXWyaKatYLrkFnAu7P7bOsrPPeCiQfZPTNAsoYr ut6W2a0THXAoKU1bo9Aly731o3iIlzysVcgs4J18CE574/aVe2cobxH+mvwV2JF+77eXetzJWcfc9CyqNmGZuccRHHTCD8XH cc/zWoLMAhtQHpT+33B1b3HT28J/EgCluj3SqCXUq/bd0MXGT0T4+bH31sFE/ReA53losoEtKA/NLi/LEapf5NW31EYKONJYzIVuut82cXjmTDB0vUHTHHz4nT3urU2BX fjgZiKzBhQiFtKfnuNepSaNL/Xl8QMeON8CN2/ScasOUir01k/zdyvXPr45yKwBhYi1rMdoY5vbEmHLpLTXwMvzRrh8n05rsh9Fb 10dzM1PcAIya0AhYrnGrytkHYeq2yy010DA53Zgqz7jm+xf6sv s9//tlf/LH+JoZNaAQoQTjcerskuu0CWeukGAIzncFGzVf4ZmIM7wr3d7n ZsIHZFZAwoRfhzQlfbq0YGz+dkd7NavCU32O8W4o5KnORSZNaA Q4c2mTeqmYQNLONkp7NnA6DzEX0OMmJEHOhSZBba3xVfCWwQJ+ LR247BtkyZkY0LaeaxDkVngHHO++WgMaW08wL7m7yN2ruCMnPB whyKzwIGS3fa0w9Rhrw+cYc7OYgtrnJETHu5QZBY4nNBw1zXiH YcCYPJuq47bTbN/2cuxM3LCQT0UmTWgEHEGU5dssnplwOHi3nfCXmaPJ52RDR7rUG TWgEIEACwkt0RdWmrNsL2XtZ9j8nDMQnwiswYUIgBgoSUt0XdS Wu1/jsnAMQvxicwaUIgAgIWWN9nfT27uto9Z+DEL8YnMGlCIAIAlFj a1wqTXttrHLPmYhfhEZg0oRADAZMv/k+jipBe22scs9piF+ERmDShEAMBMQf/qs8n+XnZJt33MGo9ZiE9k1oBCBABMEzSsTr7JlmO4pNU+ZnXHL MQnMmtAIQIA5kh+ge2hyX507f7ZrfYx6zpmIT6RWQMKEQAwQfw d9vfzJcHkPtd/sT0yxtmOWdExC/GJzBpQiACA0eIO22eTHVygbLXPeJOyEGiQWQMKEQAwVNyJBj97 aLKT7fJVrfYBS/jnmIX4RGYNKEQAwFBykx3/Oi2k+Ne6Vvt5TvhvSLYO/uuYhfhEZg0oRADAUMkmW+i558QjfCK32qd+sb1jzEnHLMQnMmt AIQIAhsr1rMKvM4PJ9WS3tdp7RSs4ZiE+kVkDChEAMJTQrcrXT Ijk/TXXZwt3CQH/UjovprctgtQ4ZiE+kVkDChEAMJrm++PRzajQKz+Kt2FdwDTZ8x 2zEJ/IrAGFCAAYLdloJpuhES1pstONf9WPYwqYJnuyYxbiE5k1oBABA KPlvtDNNaDtXwD//qs4qX4i5ZjBJ/7ftsf0pscsxCcya0AhAgAm+Labpi+Df7WEcYTw9MuRu+2gw/b/tt0iSI1jFuITmTWgEAEAE7ytT10TnLtSvkV52VP7NtSsRbmo5b YIUuOYhfhEZg0oRADAHPGXu8l3UGOHWndv49swORdN9hLHLMQn MmtAIQIApgkaIE0Dmuy55f61os/u8jbcutV2Hp7eMQvxicwaUIgAgJnidrOxB5VvV/a4Hd+Guemc99meY4MflIgBOwoAMFmxDa1r+IR7iyN3fxsmp/PcyHqODX5QIgbsKADAfJquV6YcXDnvuLfhdyLPjazn2OAHJWLA jgIAzPe2dPrWOb64Y7c99G0YLHbcRC08xyZLPsFpD/c2pNKAygMAzBd/kVzR9VZ05y2DVKPJHiRXMHXlBA3yaEDZAQDm07S8styNxUnl2w c1ZFs02atDMMv960X+FS3IowFlBwCYT9P3tLTa87tt+a73Q7cN n8+olOSsus35jsijAWUHAJivse8xddvF9qu9247jCW4JmmyHL1 +HIekJKXWb8E2RRwPKDgAwX6++x9Rtawaxjv9e9v1/NU22t/evt3hMik325HgORioNqDwAwHzdW5/Gbrv99idqsr9Xfpvsx2Xn5y0eE/mxzo/nYGTTgOIDAMw3ovuJe1xNu5xsiHO3K5vs+MqgyX78vX+9xWMiP Ogl8RyMhBpQfwCAJQY12d9fld12cii5BU9OLd8V/+DqFewqGCv9P4fQiJwaUIIAgCVGN9nBn5QNd7IJzv0c3B5PFMd Gkz1C/ICKTxx1yKMBZQcAWGJmk/1eEDdeyV+/1weD5zq27wjxZTTZQwWppskehzwaUHYAgCXmN9nfK4UOLNlna5 pjYdi4iffW+bkKBm5RJQZsKgDAEt27zIrR5HY5/jn+NXlj8hqabByAKjFgUwEAluj+P8fv3rIHfXZjc0yTjQNQJQZ sKgDAEsKXvtUD1sWg+WuvJvuJum0nXAUDt6gSAzYVAGCVvn22d ZDff8lj0mQDD022CZsKcOu7PYOt+ltBDmB5eCgaWq513sC6RGg a4Tu1EMD388ZQg3GsAY/mKhi4RZUYTDjWsZz8xKkH/PPWQFwJ006kw/hJndvn+AbWJULTCMG8uQDi3WGdKA6vcZxBXAUDt6gSAAD+0GTn Lg566FyfHf9QES1NNg5AlQAA8Mdbkx3/j0pWNdmPonWmyQZeVAkAAH+cNNm/vKdHk2dtsvX/xUj8Q68m28Nz+cdPJPCMKgEA4I+HZk7orb+/Nk5Rd73c6NNkAy+qBACAP2ububixTn6+pMkO+t3RTXbQytNkYz tUCQAAfxY2c7nGOvh1SZOtDIAmG3hRJQAA/FnVzAnfDX87zoVNtmnYjk128IMH0Xi8QQAACwpJREFUfiKBZ1Q JAAB/nDTZwq9d+uxxTXav5jjo12mysR2qBACAPx6a7OQ31rkLAhXTdU STDbyoEgAA/jhpspPBJH+ta7Ur+vK6VdBk41pUCQAAfzw32c+nOZbHkZcQzNV 3yYOa7MdTa+snEnhGlQAA8MdVk52LR/4OW+ibc3/q+MU2TTbwD1UCAMAfJ0228GX289/+Vd9kF9voLn02TTbwD1UCAMAfD03299diW5wbJO65letqbLWHN tlOulsnYcA5qgQAgD8LO7m4RS4Gk/u62jSIEEzdjbkf2sdx0t06CQPOUSUAAPxZ3mSbZk9enOuzq1tt 6y25H9rHcdLdOgkDzlElAAD8WdvJdWmyn0xvXddqV4dEk43LUS UAAPzx0GTrAxCuFL7D1szyvWZ5k/2G4aS7dRIGnKNKAAD4s7yTEzrg+E/CN9nygLn++/vX4izy1O3fQAe99fJH83ISBpyjSgAA+OOhkxPa4ue/EWqa7OB2ea7kZaac0GQD/1AlAAD8cdLJJZvs+Gehyc71ynKrrfliuxh5/ENLk/1E3fZyTsKAc1QJAAB/XHVyycb6+e+Xu7kbTf138Uaa7C8nYcA5qgQAgD9+Orkn9X+ML/hZ/uK52EzLglusMcc/WNFkY2tUCQAAf/x0ck/+P5gW2uhcXy4MHjfWcZ+tTwtNNvAPVQIAwB8/ndw/cvsbf99c/KQ4l/CrfpzvD72abFMMQzkJA85RJQAA/HHYP8XfK3//VLwy7puLX28nL6bJfjkJA85RJQAA/PHZP1mb7K8nanblVju4MRhEGW3uB5PkOB4ekIcY4B9VAgDAH7f 9U7K/LH4Sd8zJPyXnqu6zabKBhyYbAIAvz/1T3GIKLbL8c3BxcuTgRn2DO7rJNgUzgucigR9UCQAAfzz3T3Fz mYtWbp2FVjv3yaom+/0GPfnDqofluUjgB1UCAMCftV+RyuLWWQhVaEOF/jv+NeizlXHmfjCJe2t5CdO4rRC4QpUAAPDHbZOd/BI3+d1zkjBm7rK4wVUmJ9lkV2Q1nlq5rtF8Vgi8oUoAAPjjv8l +Sv200HkLI8d/TbbImvy81/RtsisiGcRnhcAbqgQAAO+KXbXQ9sWtuX7SIADlIL2a7GAEIarJ aLKhQZUAAOBdrsdVdnvxF8D6G4sxyNHGAZjQZGNfVAkAAN59+9 q6zjK4S9lqBxcoO3WabOChyQYAwL9fpGWQ5LC5W+IRcqPFlzX+ w+ChycbOqBIAAP6s6ttkHaNKNse5jjl3pXzXE/3vKfZtspM/z+SwQuAQVQIAwJ/jm+xH/AI7+LzYectN9hN12xWhxj/QZGMLVAkAAH8uabK/wxZbbSEeTZP9XtkYajCgMPtoDisEDlElAAD88dk/DWqyg/GDz/V9tjCF8K25KdTv7TTZ2AJVAgDAH4f9U0uTmhtQOZHwRbXcPSfH qRiKJhv7okoAAPCr8Zvg3Jj6GXPfcBdDUrbsv0gyVJpsbIcqAQ AcQm7XdjRoOZqhhGTmmu/cILlfn0xDX+ynabKxBaoEALC9uCM8o9UOGtCOw1aH8eia7PiW5 OMIhopXmuutq9fSxdZFhWmoEgDA3oSuevc+O9lidhm2MRK5z85 12PHU1mvi+Gmy4RZVAgDYWLLPy3V41QOukvw3Q5dhG4OJG+74y tw/e5Jjfrv23C002dgLVQIA2JXczNX12a76J3ldLcO2ByP02cnLih cX+/Jckz3/kbkqErhFlQAA9pNsyJK/xj8XRx4RcLVcV9oSZ/W936nj5jg5hbXJTt4ijEmTDbeoEgDATnLfdwYXyD/L43eMtpGw0pZWu7FBz/XZySmKTXY8jrXJrl5LNVdFAreoEgDANuQOO/lV6NZN9pPvVt8P5X9yyGNWhxRnNddMa5rs5yn8cyL3Q/ta6ngrEvh0RZVUHEAAcC35wFx4lsaB5b4BzXWBmzbZyTXmrtTr GNUTpbf4uWku4Yclz8tbkcCnw6uk+7ECAMcTTsu1Z2ly3lxIyT 5ME7m318R3dcrMB9cLOkYVjJmLuWLeeBzTAx3BW5HAp2OrZNCx AgBnk4/KhaeoMG/yT9U9mcN3RLJ/7RJny1DyG/b9ORi/Yrp4HNMDHcFhkcCh06rkl/pXde4IAAAEko3R+6f3r0sCi7tMIdon1YppXgE+3xHx+6vjS616 nPjdKvxQF3ZcdaanOYjPIoE351RJvMmDbdzxPAKAs8VHZXCcrg 0pOOqfTL9V15a5fUfk3mK/lJbxTbfEgf3EJjsOWD9Fxe2DuC0SuHJClST3m+aT5AhTQwcAl3 KN0ftz/Kc5nqh7+4mdXPBzfFly7S2pGy3IhnyBPqvx7fpgnk8r/Oia7GSomsUWb5nDeZHAib2rRDgv9AfKQ5MNAP+VbGu+f10e0pN q5p5MExa8GooTDVtEN5pXm3Wc5OeaEeJ4nlKTHZRT7vbkc2xZb y9bFAmW27hKikdM8oLkxnCyaQHAiWRnk/x1VUiP2F5/L3vsTfYu74Lca866hOJrtHhvPEjyQSR/ldeS/Kt+aYN4iCEgJ1zOnvBEnrYdIZfld4r2z53UxpevaIriDZzch8H FOfGw3h4PACyhPEtXRRW/CJ5UKxC/GjQxb/ouKL7yqt+G8uPODfi9JR6tei3V+enLTySvX6b44z9pbq8YITds LrCKz5Mh5T73wFEosuQ2K27C5J73uWMBwA/5eFx1csbnf/KH3MXKM/+kV4PwlpTfhvoP44m+n7w/B1daV2G6foKTQnrrYdDgcRUl/5SslpbPPXAUSo7pjEhu8twnFVsdAG4gH4+rTs7cef79Nfez/sC/7dUgvBOFD5XDxtefkV6HS8gVebHtST6m5DXVUeV+LV4WbOTkLf HndaGO4CiUQFwWySoR/hT/9fv57PUAwCkWHqFCK/B9Kxcbi7opDiakS/9hfMFDkz2d/GiEdkh5y1Pq0OQrc1Pk7pKvET73wEscX/LDC1JffHjFRwsA2EXuPC++LKxT9At5M7m86T98/pvD33Ed9uO7yf5HSPXP2GRr/qoPI1lCQnjJQnposrNTig/eJL5LGHPgkgAAExXfC+2Dt4+ztVxWk3nOXfb+nPx8a95WEcfzp jr5vIS7cmPWLTlXLbm/CvNaP/fAS5MtnJiC+N7pqwEALJB8HXQcueOA+8olOZn295NcF3VSYh0u ROhB42eXvOWZ22THgVkXIn/uwexQgu0atc1m8SCTVwQAOAmvkkDuJav85PunaTGP5nAtQUcU/Mn0+IKn1vLscp1b8k9ywBWfL7eyye4iHnbyigAAJ+FVkpN81eb ey/GfVoQ8ymHLwSBTq6Rnc/3ffXvkHgYAzMfbRKbsmw/usB+abOgc0mQDANAFbxaN3Lv4khf0wUtDRzTZAAD84c2id+2r+ fgFoot5VTKow6bQAQAd8WZBERUCjb2b7GnBAwAuwfsFRVQINLZ ssqfFDAC4DS8aFFEh0JhUJbTXAIAt8LpBERUCjW2a7DlxAgAux 0sHRVQINGZUCb01AGAXvH1QRIVAw2+TPSEwAAACvINQRIVAw2O TPSEkAACSeBOhiAqBhq//z2hmBgMAQIz3EYqoEGisqRKabACAT7yPUESFQGNlldBkAwC88f A+0v8HlnPIsXmOfJy5FYEtuagSqhYA4MSqpq2v5/+/bf39/4s1/qvy9l/0ao4vBhBztDfYqwAAADgDTS0AAADQGU02AAAA0BlNNgAAANAZT TYAAADQGU02AAAA0BlNNgAAANAZTTYAAADQGU02AAAA0BlNNgA AANDZ/wEKvo3O+ObgkwAAAABJRU5ErkJgggA=[/img]
Old Aug 8, 2018
Crap. Try image again
Old Aug 8, 2018
plateau's Avatar
Sure, bro.
The old one was not torn or worn but I decided to put everything (shocks, struts and stopper) brand new.
Old Aug 16, 2018
plateau's Avatar
Hi, folks
After same days trying to find the main issue I think there is some clearance/backlash in the power steering.
I have recorded this video to explain a little more about. I have replaced the rack slider with these one 6 months ago:
Regards,
Peter Rose.
Old Aug 19, 2018
Recheck all fasteners, maybe something has become loose!
You may be able to determine where the noise originates using a mechanics' stethoscope or even a simple long dowel or long screwdriver held to your ear
You will need someone sitting in the car turning the steering to produce the noise while you search
Old Nov 14, 2018
plateau's Avatar
Hi, everybody
Good news, guys!
The problem has been solved and it was related to the springs.
When I replaced all mentioned parts, I chosen Fabrini springs instead of Showa’s because they weren’t available.
Analyzing the old spring, I realized that the last turn was too close to the next stage (as shown in the image below) and there was rust and some evidences of impacts.
So, I decided to disassemble the suspension and the new one had the same “damage”.
Thus, I have put insulators on both sides (top and bottom) as described in the image below.
And voilą!!!
No more hits or noises even though I hit a speed bump with a high speed.
I don’t know if Showa springs have these insulators (top and bottom) but this trick saved my life.
It was driving me crazy because I spent a lot of money to let the suspension too much smooth.
That’s all, guys!
Thank you so much.
Old Nov 14, 2018
ow... it was this simple...
yes, the stock ones do have the plastic pieces. (Couldn't even remember, I have been so long in aftermarket springs)
