Rpm at 500?
Rpm at 500?
So just bought a em2 2003 ex and I noticed the rpms are 500 at a dead stop. Other then that it runs great. Has 129,600 miles on it. Is an automatic transmission. I believe it' a vacuum leak but wanted to double check.
Re: Rpm at 500?
Are you watching the tach on the dash? I won't trust that to be absolutely accurate. I sooner trust the data displayed in a real scanner data list
Does it SOUND like it's idling too low? Is it a problem?
Tried cleaning throttle body and make sure IAC is not stuck, rotating valve oscillates freely?
Relearn idle?
Vacuum leak not likely. Vacuum leak will normally cause RPM to raise.
Relearn idle?
Re: Rpm at 500?
Relearn idle?
Relearn idle?
lambocivic
Aug 22, 2004 07:33 PM
supz
Sep 8, 2003 04:59 PM
HondaGuru
Mar 2, 2003 05:14 PM
