8th Gen 2006 - 2011.
Possible front driver shaft or axle seal leak
Old Feb 14, 2018
Wizwazz's Avatar
Wizwazz is an unknown quantity at this point
Not sure what this leak is. I was changing my front tires and took notice of this leak. Help
Old Feb 14, 2018
Re: Possible front driver shaft or axle seal leak
need a new axle shaft, boot is split
Old Feb 14, 2018
Boot split open. Replace axle (simplest)
or reboot it---but there are caveats: super messy and time consuming, and if there is internal damage from lack of lube then you rebooted a shot cv joint and wasted time and money
Old Feb 14, 2018
axles are cheap enough, i choose to simply replace the entire units
Old Feb 14, 2018
Wankenstein's Avatar
The right side CV axle boot split open and leaked out grease on my '95 EX about four months and to this point no clicking or noticeable issues. I know eventually it will need to be replaced but I'm waiting for it to make a clicking noise before I replace it. Should I replace it sooner?
Old Feb 14, 2018
That's entirely up to you
Old Feb 14, 2018
Is that gerbal eating the leaf a representation of my car's right CV inner axle eating away at the differential gear?
If I misread that and I really can wait to replace it..then, I would like to keep it on to see how far it will go until it starts clicking.
Old Feb 14, 2018
Naw dude that's a Guinea Pig........Representing yourself in the ongoing experimental testing of the lifespan of an open CV joint (time to explosion, or maybe distance driven until a tow truck is needed)
Old Feb 14, 2018
Looks like I am not informed about the various ways of axle failure. Can it lock up on me driving in a straight line. Obviously the grease in the joint serves a function... However, I've personally never had one fail other than clicking sound during turns. Now my question is: should I replace it very soon?
Old Feb 14, 2018
It might start off crackling/popping (ratchet noise) during a tight turn while accelerating.....typical first thing people notice
eventually get bad enough to crackle while turning without accelerating or crackle while driving in a straight line....on some cars
I've also seen joints break, explode several 3/4 inch steel ***** all over the ground, and break the joint or the axle shaft
I've seen open and missing joint boots....yet some of them keep going for a long time like that....and I've slapped fresh grease on open CVs just so it might keep going a little longer
Old Feb 14, 2018
I have a used spare axle at home .. just been too lazy to change it out. Thanks for the replies.
Old Feb 14, 2018
Huh, dong, why are you posting like the OP?
Old Feb 14, 2018
Originally Posted by sdaidoji
Huh, dong, why are you posting like the opportunity?
The Opportunity....is that a rapper?
Old Feb 14, 2018
Nah, just asking
Old Feb 15, 2018
Inboard joint or outboard joint?
Old Feb 15, 2018
outer joint
Old Feb 15, 2018
sorry, autocorrection. Corrected to "OP"
relative4
Jan 18, 2018 07:10 PM
skeeter65
Jun 19, 2013 10:04 PM
RonJ
May 27, 2010 12:50 PM
GuiGJ
Jul 27, 2009 05:11 PM
