DIY brake pad replacement and rotor resurfacing
Old Jun 18, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
ok i have yet to do this, but i will do a DIY, i realize that most ppl dont have a rotor resurfacer, so u can get new rotors if that is more convenient for you
altho i stress resurfacing because it is cheaper than using new rotors
i will also take pics of the tools that the PROS use so you can recogize and buy so u have these tools in your collection but it should be up tomorrow at about 11pm or so, until then, if you have any questions, just let me know because im sure someone can answer them
and i have seen how the employees at my dads shop does brakes, and thats the way they have been doing it for YEARS so i will show how to do it that way, also i will recommend various air tools just to make the job go faster
Old Jun 19, 2003
WannaBFast's Avatar
on the left is the piston spanner, and that can be picked up at any place that sells tools
on the right is a tool used to loosen screws with a tap of the hammer, im not sure where to pick this one up, but it makes taking the screws off of the disks a LOT easier
Old Jun 19, 2003
WannaBFast's Avatar
you will also need
white lithium grease, a 17mm socket, and a 12mm socket
using the 17mm socket, take off the bolts holding the entire brake caliper out, using the 12mm take the brake pad holder assembly out
reset the caliper piston like so
Old Jun 19, 2003
WannaBFast's Avatar
take out the disks, using the tool mentioned above, replace or resurface
before u install the new pads, take the 2 pins out of the pad assembly and lube them up with the lithium grease replace
install the pads, attach to caliper, install the disks, install the caliper and pump the gas until desired resistance
and your done
ayoitzjulesdx98
May 14, 2015 08:29 AM
edgenet
Apr 28, 2015 07:49 PM
bsmiley
Apr 27, 2015 01:27 PM
tattedlariat
Apr 12, 2015 07:55 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
