My car won't redline!
Old Jun 16, 2003
R1Style's Avatar
Angry My car won't redline!
I have a '03 LX Coupe w/ Auto tranny.
Up until yesterday, I noticed my car wouldn't redline when I stepped on it. It seems to be shifting at about 5.5k rpms which I can't explain because it would always shift at 6.5k up until now. No warning lights have come on and the entire car seems to be running fine with the exception of the whole redline thing.
Has this happend to anyone else? How can I fix this?
I'm thinking of resetting my ECU (pulling the fuse) but is there anything else I can do?
Thanks.
Old Jun 16, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
It's an auto tranny.... why would you redline it. BTW, your ECU learns how you drive. So if u drive normal, it will adapt to your driving style.
Old Jun 16, 2003
Devst8n's Avatar
Devst8n is an unknown quantity at this point
While I agree the ECU does learn how you drive and adapt it doesnt change the shift points at all. Those settings are directly programmed into the ECU with shift points according to the throttle position and speed.
r1 style, double check the kick down cable to the tranny. If you check the throttle body on the the engine you will see a cable run from the drivers side firewall (throttle cable) and you should notice another cable run from the throttle to the auto tranny. This measures the amount of throttle you are giving the car and it picks the appropriate shift point. Make sure there is a little bit of play (1/2") or so max. If there is alot more it needs to be adjusted. Take it to honda and have them do it. Cables will tend to stretch and adjust so this may be the car working itself in. If the cable and all that is in place take the car to honda and have them check the car out.
Although I dont have an automatic I have noticed with other car manufacturers that sometimes the car wont shift as high in first gear. The second to third shifts will be at redline but I think the 1st to 2nd sometimes is lessen as to no put as much wear on the tranny. There is alot more of a jerk at the lower speeds.
Old Jun 17, 2003
R1Style's Avatar
Thanks for your help guys! I fixed the problem... my throttle adjustment bolt spun itself set to have wayyyyy to much slack. Fixing the problem even made my car feel faster.
Old Jun 23, 2003
Civicster's Avatar
pu in d2 n slam the gas if u want to redline.
also i manage to redline in second gear while in D mode....basically how i got it is press hard on the gas but keep ur foot in that spot without budging a nanometer......i hit 6.5k easily
Old Jun 24, 2003
Distinctive's Avatar
Smell My Face!!
drive harder!! j/k
Old Jul 22, 2003
civicsedanlx01's Avatar
civicsedanlx01 is an unknown quantity at this point
R1style Did u fix the problem urself cuz my car is doin the exact same thing as yours for the past couple of days now. But it only happens on and off. I need to fix it though. Do you just tighten a bolt? is it that east. Thanks.
Old Jul 23, 2003
Elite's Avatar
Elite is an unknown quantity at this point
lol I hit 7k with my automatic
Old Jul 23, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
AT redline is at 6750rpm.
Old Jul 23, 2003
Restin's Avatar
Restin is an unknown quantity at this point
Time to do the major upgrade here. Time for you to go out and get that tranny swapped for 5-speed
Old Aug 13, 2003
mos_skeeto's Avatar
mos_skeeto is an unknown quantity at this point
How the heck do u get 6.7 or 7k???
Old Aug 15, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
welcome to the world of automatics ... ;P
usajags84
15
Aug 19, 2015 03:12 AM
chrisod12
Apr 26, 2015 01:30 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
spoony
Nov 7, 2001 11:01 AM
