Sponsored by:
Sponsored by: CARiD
air/fuel ratio gauge
Old Jun 12, 2003
Rodawg's Avatar
Rodawg is an unknown quantity at this point
how and where do i hook the gauge up...
PLEASE HELP!!!
Old Jun 12, 2003
Samari's Avatar
search, i seen topics on how to hook it up
Old Jun 12, 2003
slystad810's Avatar
c'mon man you're not a newbie...Sticky in tech
CLICK HERE
Old Jun 12, 2003
Titleist71's Avatar
You gotta run it in w/ the A/F Ratio wire on the ecu. I know a guy at Honda and he faxed me the ECU diagram for A/F output. This is the only way. Get that diagram to get the correct wire. bada bing, your done.
Old Jun 12, 2003
Titleist71's Avatar
the diy that boilermaker did may work but it is not accurate. Doing it through the ECu is precise.
Old Jun 12, 2003
slystad810's Avatar
Just curious, how is that more accurate?
If accuracy is what he's shooting for, then he should've got an EGT gauge.
Old Jun 13, 2003
Logan3024's Avatar
Where exactly do you wire it to the computer? got any directions?
Old Jun 13, 2003
Titleist71's Avatar
call honda and get a wiring diagram. There is no Haynes manual yet. The diagram is of the A/F ratio output on the ecu. When you find that wire run them together. The wire off the sensor does give a reading but its the reading right from the computer telling the car/injectors if its too lean or rich...and to make an adjustment, that you want for your gauge.
Old Jun 14, 2003
Parisdreams's Avatar
Parisdreams is an unknown quantity at this point
Connector A (31 Pins)
1-blk/wht-Primary O2 sensor heater control
2-yel/blk-Power Source
3-yel/blk-Power source
4-blk-Power ground
5-blk-Power ground
6-wht-Primary O2 sensor
7-blu-Crankshaft position
8-yel-Sensor return volt
9-red/blu-Knock sensor
10-grn/yel-Sensor ground
11-grn/wht-Sensor ground
12-blk/red-Idle air control valve
13-wht/blk-EGR Valve position
14-blk/wht-Secondary O2 sensor heater control
15-red/blk-Throttle position sensor
18-wht/grn-Vehicle speed sensor
19-grn/red-MAP Sensor
20-yel/blu-Sensor Voltage Supply
21-yel/red-Sensor Voltage Supply
23-brn/yel-Logic ground
24-brn/yel-logic ground
25-wht/red-Secondary O2 Sensor
26-grn-Top dead center sensor
27-brn-Igniton coil 4
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
Connector B (24 Pins)
2-yel-Fuel injector 4
3-blu-Injector 3
4-red-Injector 2
5-brn-Injector 1
6-grn-Radiator fan control
7-red/blk-A/T Pressure control solenoid valve A
8-red/wht-Engine Coolent sensor
9-blu/blk-VTEC Oil pressure switch
10-wht/blu-Alternator L Signal
13-wht/red-Alternator FR Signal
14-blu/red-EGR Valve
15-grn/yel-VTEC Solenoid valve
16-blk/red-A/T Pressure control solenoid valve B
17-red/yel-Intake air temp sensor
18-wht/grn-Alternator control
21-yel/blu-EVAP Canistor purge valve
Connector C (22 Pins)
1- wht/blk-A/T Pressure control solenoid valve A
2-yel/blu-Torque converter clutch solenoid
4-grn/wht-Shift solenoid B
6-blu/blk-Shift Solenoid A
7-wht/red-Mainshaft speed sensor
8-brn/wht-A/T Pressure control solenoid valve B
9-red-Position switch D3
10-wht-position switch R
11-blu-position switch 2
12-blu/wht-position switch neutral or park
14-grn-countershaft speed sensor ground
15-blu-countershaft speed sensor
18-blu/yel-position switch D3 or D
20-yel-position switch D
21-wht/grn-mainshaft speed sensor ground
Connector E (31 pins)
1-grn/yel-Immobilizer fuel pump relay
2-wht/red-Secondary O2 Sensor
4-pnk-Sensor ground
5-yel/blu-Sensor voltage source
6-blk/wht-Secondary O2 sensor heater control
7-red/yel-PGM-FI main relay 1
9-yel/blk-Ignition input signal
12-blu/orn-Cruise control signal
13-wht/blu-Interlock control unit
14-lt grn-Fuel tank pressure sensor
15-grn/red-Electrical load detector
16-lt grn/blk-Power steering pressure switch
18-red-A/C Clutch
20-blu/red-EVAP bypass solenoid valve
21-lt grn/red-EVAP Canister shut valve
22-wht/blk-Brake pedal position switch
23-lt blu-K line
24-yel-Multiplex control unit comm line
26-blu-Engine speed pulse
27-red/blu-Immobilizer code
29-brn-Service check signal
30-red/wht-Write enable signal
31-grn/orn-MIL or check engine light enable
Here you go the ECU diagram 6thpin on first connector hope it helps.
Old Jun 14, 2003
to simpilify installation it can be done at the connector on boilermaker's post but i'd recommend doing it on the other side,not on the side that plugs int the sensor itself but the other side of the connector. it sshould be white (always double check) as that wire is the that feed the ECU its info, it runs from there to the ECU.
Old Jun 14, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
so the best way to wire up the A/F ratio guage is through the white wire on the first connector (plug A) on the ECU???
Old Jun 14, 2003
Titleist71's Avatar
i hope so....i have yet to hook mine up. be careful if you put the wrong just to the gauge you'll blow the focker up.
Old Jun 14, 2003
Titleist71's Avatar
What doesn't kill you makes you stronger....
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
