Oven baked Taillights - HELP!!
Old Jun 11, 2003
Jackseric's Avatar
Jackseric is an unknown quantity at this point
Those of you that have put your taillights or headlights in the oven. How did you keep the plastic off the oven rack? I cleared my headlights a few months ago without using the oven or any heat. That was EASY!! The black glue was soft enough without heat.
I bought a set of TYC Elegante taillights with the intent to open them the same way to paint the inside to match my satin silver. To my dismay, the black glue on the TYC's is a totally different kind of glue. This stuff has dried HARD and has no give at all.
I see some people have baked thiers in the oven. I've found posts anywhere from 200 to 350 degrees for 7 minutes up to an hour. I can handle that part (i hope), I'm only worried about keeping the taillight assembly off the oven rack to avoid melting a certain spot or burn marks. Did you guys set your lights on a towel or aluminum foil or something? What can I use to set it on that won't catch on fire, or burn/melt the plastic taillight?
Thanks,
Eric
Old Jun 11, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
i just laid them right on the rack, i've done my headlights as well as my altezza's and i've had no problems- about 275? for about 6 minutes or so, but you've gotta put them in a few times, after a few minutes, they cool right off and they'll crack if you don't re-heat them
Old Jun 11, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Aluminum foil.
-Kre
Old Jun 11, 2003
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
put them on a towel
then call the fire department
Old Jun 11, 2003
dirtEsanchez's Avatar
Better Then God
dirtEsanchez is an unknown quantity at this point
Can always deep fry them for a little extra crunch.
Get a hair dryer and see if the heat will loosen the glue..if not the over may not be helpful...
Old Jun 11, 2003
bth Go Army's Avatar
bth Go Army is an unknown quantity at this point
Cookie sheet
Old Jun 11, 2003
fraga's Avatar
Wicked Moderatuh
Don't forget the Lemon Pepper...
Old Jun 11, 2003
Jackseric's Avatar
I tried an 1875watt hair dryer for nearly 4 minutes and it didn't make a bit of difference.
Old Jun 11, 2003
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Could try a heat gun or something, that should work quite well I would think.
RIPSAW
Aug 16, 2015 12:14 PM
TiggerDX
Jun 18, 2015 01:43 PM
TuffVietta
Aug 25, 2010 10:43 PM
aZnVoYCe
Aug 24, 2002 05:14 PM
Bartkat
Nov 9, 2001 01:16 PM
