Help. Engine light came on.
Old Jun 10, 2003
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
2002 LX Automatic w/ about 13,000 miles
I put in the HP 4-1 headers w/ high flow cat about 3 months ago. I got an O2 Sim for it about 2 months ago. Now for some strange reason I noticed yesterday that my engine light was on. Got to work today checked the O2 sim wires attached to the ECU and everything seems to be fine.
I was thinking that the engine light was due to the O2 Sim possibly being defective.
Could it be possible that the O2 sim from Lake Performance is bad? It's the only thing I can think of that would be throwing the check engine light.
Car seems to run fine and shift gears ok. Oil light isn't on so I'm assuming it's not low oil. And yes I did check the gas cap
Old Jun 11, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
well honda has the check engine light turn on at certain intervals, so it might just be your checkup period, stockify everything, and bring it in
Old Jun 11, 2003
I doubt that is it. Honda has a service ligth come on at certain intervals. You turn that off by holding in the two guage pod sticks if I remember correctly. I've already had the service light come on.
Anyone else?
Old Jun 11, 2003
robbclark1's Avatar
Retired suspension supermod.
He is talking about the check engine light not the maintenence light! Geesh has no one figured that out yet??
anyway, did u reset your ECU by taking off the battery cable???
Old Jun 11, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
yea the 15k check
Old Jun 11, 2003
Samari's Avatar
that is true that honda has the check engine light come on at certain milages. To reset the check engine light. Do this:
1. Turn off car
2. Push and hold in trip reset button (odometer)
3. Start car while still holding the reset button
4. Let go and it should start blinking and turn off
Old Jun 11, 2003
robbclark1's Avatar
AHHHHHHHHHH!!!!! He is NOT talking about the MAINTENENCE LIGHT!!!!
Hey Alienmonkey
1) check to make sure everything is installed correctly
2) Reset the ECU by taking off the battery cable for 10 min.
3) hopefully it will go off.
4) I can recommend a shop in the area that maybe able to help.
Old Jun 11, 2003
solar's Avatar
solar is an unknown quantity at this point
1. Turn off car
Its the mainatance required light your talking about not the "check engine" light. The check engine light only comes on when there's a problem.
Old Jun 11, 2003
Samari's Avatar
my bad, i read the thread wrong. i thought it was mainatance light.
Old Jun 11, 2003
cambo's Avatar
I wish I was asian
you could have a bad sensor somewhere...
Old Jun 12, 2003
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
maybe it's some other problem with the car? I say take it in to Honda. If it's still under warrenty I belive they can't charge you to check and see what the problem is.
Old Jun 13, 2003
Thanks robbclark1 I tried my best to say it's not the maintenance light. I've already taken care of that at 8,000-10,000 miles when it came on.
I'm wondering if it is a bad spark plug. I've read that the oem spark plugs are not the best. I've ordered a set of Denso Iridium IK22's. Gonna try changing them (planned to do so anyway, just getting around to it). If that don't work, I'm gonna try to disconnect the battery for about 10 minutes and see if that helps. I had disconnected the ECU plugs for a little bit(didn't want to lose my radio settings again, but I'll disconnect the battery the next time.
I doubt it's a bad sensor. I have no cat and I took care of that problem with an O2 simulator from LakePerformance parts. The O2 sim could be bad, but I'm gonna switch the plugs out and disconnect the battery before I send back the O2 and get a new one.
Thanks for all the help. And to clarify things it's not the Yellow MAINT light in the lower center of the guage pod, it is the Orange light shaped like an engine on the Left of the Guage pod.
On a side note robbclark1 if you know of a good paint place I can get a polyurethane kit done at for a reasonable price PM me please.
Old Jun 13, 2003
konstanting's Avatar
konstanting is an unknown quantity at this point
ok the way i understand it is that the CHECK ENGINE light doesnt just turn off. ... like when ur gascap isnt tight (for example) tightening it wont make the light go off, u will need to reset it. so i would assume that putting diff spark plugs in wont fix ur problem, u need to reset the freaking light.
i had it come on twice, both times i had a messed up cat, (the HX has two i think and one was bad)...so i went threw some stress already...
Old Jun 13, 2003
How exactly did you reset it?
thana
Jun 15, 2020 07:05 PM
jetcare101
May 8, 2015 01:33 PM
Flipg123
May 8, 2015 01:15 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
