Want to swap engines.
Old Jun 10, 2003
CIRE5109's Avatar
CIRE5109 is an unknown quantity at this point
Is there a fast engine out there that can drop straight into my 2001 civic dx? I would really like to do a swap! Thanks
Old Jun 10, 2003
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
the only engine that can be drop are the K series, off the RSX-S. B series can be done, if you find a 01 acura.
Old Jun 10, 2003
Weaponx12o's Avatar
are there motor mounts out to put a 2001 b18 engine into a 01 civic? i thought hasport was still working on it
Old Jun 10, 2003
robbclark1's Avatar
Retired suspension supermod.
They are still working on those mounts. I think it will be awhile for those. The only engine that has been in dropped into a civic is the K20. Now the K20 comes in various forms, 160hp, 180hp, 200hp, and 220hp. The 220hp one will be expensive because it will be an RSX-R from Japan. The most common swap (haha like it is really THAT common) is the 200hp RSX-S k20 motor. I don't know all the little codes after the K20 that distinquish between motors but whatever.
Old Jun 10, 2003
Bellz's Avatar
Which car has 180hp?
Correct me if I'm wrong here, but...
Base RSX and Civic Si = 160hp
????? = 180hp?
RSX-S = 200hp
RSX-R = 220hp
Old Jun 10, 2003
Jodster's Avatar
Post Whore General
Here is some more info
Civic SI/Base RSX-K20A3-160hp
RSX type S-K20A2-200hp
Civic type R-K20A1-210hp
RSX type R-K20A-220hp
Old Jun 10, 2003
tripledoublegs's Avatar
Euro-Spec
I thought the Vic type R has 19something. Maybe I was wrong... Yeah, I was probably wrong...
Old Jun 10, 2003
khmaitiger's Avatar
khmaitiger is an unknown quantity at this point
cant we do a k24?
Old Jun 10, 2003
khmaitiger's Avatar
from the accord or tsx? or something like that
Old Jun 10, 2003
Jodster's Avatar
Post Whore General
Yes you can swap the K24 out of both of them. I would recommend the K24A2 out of the TSX. If not then get the K24 block and put the K20A2 head on it.
Old Jun 10, 2003
khmaitiger's Avatar
hah yea i agree with the frank engine. it seems so sexy and i dont think its been done yet. you would be one of a kind if u did it. what would it be putting out tho? like 250-275?
ahhh drool it jsut sounds so nice
Old Jun 10, 2003
Jodster's Avatar
Post Whore General
It has been done. In an EP. K24 block, K20A2 head, but with the K20A3 ECU. so the cut off was 6800rpm. It made almost the same results that the K24A2 in the TSX.
Old Jun 10, 2003
khmaitiger's Avatar
wait wait umm then the type r head hasnt been done right?
Old Jun 10, 2003
Jodster's Avatar
Post Whore General
No, the K20A head has not been used on the K24 block yet.
Old Jun 10, 2003
khmaitiger's Avatar
how much would that put out?
Old Jun 10, 2003
Logan's Avatar
Logan is an unknown quantity at this point
Unless it's been done and reported on some website or in some magazine, there is no one here that would know that one. In fact, even someone that's been building engines and working with performance engines for years would be giving a very rough estimate on something like that.
Old Jun 11, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
if you put in a k20 from a 2002 and up, you need to upgrade your immobilizer unit to the 2002 unit or else your car wont work with the k20
it should run you around $150 from the dealer also you need to get the ecu flashed by them as well
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
