coilover q's
Old Jun 9, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
coilover q's
i just got hp coilovers for my vic. so can i still have my stock height with them? or will it still be lowered if i set them as high up as i can? i am getting 215/55/16s if i can still get my stock height.
Old Jun 9, 2003
Weaponx12o's Avatar
if you adjust it you can get up to stock height, or a little lower. but why did you get coilovers if you still want a stock height?
hp coilovers? ive never heard of them
Old Jun 9, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
Ive heard of them, I think they are full coilovers.
Old Jun 9, 2003
robbclark1's Avatar
Retired suspension supermod.
You should be able to get close to stock height. But why get coilovers and run at stock height?
Old Jun 9, 2003
Chrissy's Avatar
well, i just want stock height in case i am going to an area that has a lot of speed bumps.
Old Jun 10, 2003
robbclark1's Avatar
Well be aware that if you are going to adjust them then i would it for months at a time. Technically you need to get an alignment done each time you change the height.
Old Jun 11, 2003
Drifter's Avatar
Drifter is an unknown quantity at this point
No, if I remember correctly with the rings at the top your still down I think was either .75 or 1. The best way is try and avoid the speed bumps the best way you can, cause it's not like airbags where you hit a swith to raise the car you'd have to plan for where your going raise the car before going. If your worried about speedbumps then I woudn't even bother dropping the car cause even some entrance ways into certain places have a bigger lip then some speedbumps.
Old Jun 12, 2003
Chrissy's Avatar
got them installed today. is the ride supposed to be bumpy and stiff? cuz hell it is!
Old Jun 12, 2003
Slow+Furious's Avatar
Slow+Furious is an unknown quantity at this point
Hey newbie question and while we r on the topic of coilovers, which are the ones u experts recommend? Best bang for buck? Thanx
Old Jun 13, 2003
Weaponx12o's Avatar
which coilovers?
for sleeved coilovers i recommend ground control or skunk2
for full coilovers i suggest getting B+G or Tein
i have B+G coilovers with a 2.25" drop, check out my ride section to see the drop
search for coilovers and it should answer your questions
Old Jun 13, 2003
Right on Weapon X thanx!
Any (sleeved or full) coilovers will work. I just wanna get a sweet drop (like yours! nice!) AND we Torontoians up here get snow so I'd like to raise my ride when winter swings around. Hopefully dude those B+G or Tein full coilovers are available up here in Toronto.
Old Jun 13, 2003
opto_isolator's Avatar
Hey Chrissy....
Where did you get them and for how much? I only saw one place online that sells them - for $1000. They look pretty nice...
Old Jun 14, 2003
Chrissy's Avatar
i got mine off ebay for 90 bux. almost any coilover would work for our cars as long as you modify them right by putting an extra 3 inch sleeve on the front ones. but they are stiff and bumpy as hell so mybe i will cut some 96-00 springs and use that spring instead. this installment of the coils was a big diy for me
Old Jun 14, 2003
Oh - so you just got the "gen 1 coilovers" from HP racing than? I thought you bought the "gen 2 coilovers," which are actual full coilovers from HP (they have a matched strut with them). That's why the price diff.....But hey - that's cool.....
Hope they work out for you!! Congrats on installing them - eventually when I get mine I'll be in the same boat!
Old Jun 14, 2003
Chrissy's Avatar
yeah, i just followed mex's diy and it took me about 3 hours. i had to buy a 3 inch sleeve for the front though, but i'm thinkin about replacing the shorter coils with the 96-00 front springs and removing the added 3 inch sleeves to make a "longer" spring for the coilover.
Old Jun 15, 2003
6fingaz's Avatar
6fingaz is an unknown quantity at this point
hey i got gz coilovers they barely dropped anything does anyone know why ?
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
EM_WON
Jul 22, 2015 06:49 PM
