drive types question
Old May 29, 2003
R3DL1N3's Avatar
couple questions
is AWD the same as 4WD?
and is 2WD the same as RWD or FWD?
Old May 30, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
awd=4wd (all wheel drive = 4 wheel drive)
2wd can go both ways i think, rear wheel drive or front wheel drive..either way its 2 wheels. ^_^ not sure tho...correct me if i'm wrong
Old May 30, 2003
Weaponx12o's Avatar
you're right..
Old May 30, 2003
7thGenerasianCivic's Avatar
I dunno...I always consider 2WD as front only and RWD as the rear. Duh
Old May 30, 2003
klam's Avatar
klam is an unknown quantity at this point
Generally 4WD refers to vehicles with a high/low transfer case, usually off-road trucks. AWD usually refers to road vehicles that send power to all four wheels but do not have a high/low transfer case. (e.g. Quattro, Subaru, 4Matic, etc.)
But for most purposes the terms are used interchangeably.
2WD is sometimes used to refer to the two wheel mode used by 4WD vehicles that can be switched to. Whereas a RWD is purely RWD all the time or FWD, FWD all the time.
Old May 30, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
AWD is sometimes considered the variable ratio systems... like Quattro, 4 Motion, Attessa, 4-Matic, etc... that can transfer varying amounts of torque between the 2 axles as needed.
4WD is usually a fixed amount of power transfer like on a pickup truck.
Xuhme
21
Aug 7, 2023 03:40 PM
smmahan
Apr 15, 2015 08:17 PM
dano2005
Apr 14, 2015 01:58 AM
klam
Nov 15, 2001 05:30 PM
