cam gears, pulleys, fuel pressure regulator
Old May 29, 2003
jayham1's Avatar
jayham1 is an unknown quantity at this point
has anyone installed any of these. it seems that no one has them on their cars, please correct me if im wrong, but are these bolt ons a waste of time?
Old May 29, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
I know some people have cam gears and pullys, but i dont know about the regulator
Old May 29, 2003
got-K20?'s Avatar
got-K20? is an unknown quantity at this point
pulley is the best bolt-on mod you will ever have, cam gears I have no experience with, and fuel regulator is a waste of time.
Old May 29, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
My friend installed cam gear, pulleys, header,apex-n1, and ebay downpipe. After every thing he puts on i can still pull a way from him. All i have is a ghetto intake and exhaust.
Old May 29, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i have an unorthodox crank pulley installed....great stuff!!
Old May 29, 2003
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
any negetive side effects from the crank pulley?????????
Old May 29, 2003
civicvtec1ps's Avatar
Search and Learn
i have AEM pulley for sale btw..140 SHIPPED PM me if you are interested.its silver fits on DX/LX/EX . gbc sells them for 146 shipped.
Old May 29, 2003
Logan's Avatar
Logan is an unknown quantity at this point
Things you need for a fast Civic: Cam gears, larger fuel injectors, bigger throttle body, more powerful fuel pump, cold air intake, ability to set VTEC to come on at lower RPMS...thus changing to a more aggressive cam profile earlier, remove the AC, get custom exhaust without muffler for maximum flow after cat, stronger valve springs, headers, probably wanna replace spark plugs and wires, but I don't know how efficient stock plugs and wires are. Then add a turbo and watch those mods REALLY come to life. If you wanna get ridiculous, let's just take out the windows and install plexi instead. Hmm. Take out the back seats too. Get rid of radio and speakers....and toss that spare tire in the garage. Hello race car, goodbye economy car...sure hope you have another ride to work.
P.S.- I've never seen a pulley application or read about them, but I know I've read an article somewhere about BMW or some other company stating that using pulleys would void the warranty and possibly damage something...yes, very vague.
Old May 29, 2003
ohmysac's Avatar
about the crank pulley..i've heard it both ways...may cause premature wear...or has nothing to do with wear...
Old May 30, 2003
CrazyCakes's Avatar
yeah i've heard both ways too i'm jus trying to get a def. answer
Old May 30, 2003
jayham1's Avatar
does anyone know the hp after adding pulleys
Old May 30, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Pulleys free up about 2/3 HP to the wheels? on our cars at most. A properly designed pulley will not cause any damage. So get it from a reputable co, like UR/ AEM. You definitely do not want a lightened pulley, as that will cause you problems. It's got to do w/ harmonic damping.
Get a CAM gear w/ a new CAM, as it will allow you to shift your powerband (it doesn't make much sense to get one w/ o a CAM, as the install is labor intensive & not worth the cost)
Larger fuel injectors/ fuel pumps/ plugs are not required unless your car is producing close to 200 crank HP.
Old May 30, 2003
runner1738's Avatar
cam gear from what ive heard is more for the heavily modified car, it doesnt help when you barely have anythin, and pullies will just free up horse power but it means you cant run a huge sound system, if some one made a regulator for ours that is new to me, but our cars dont do to good on just bolt ons, it would more more if you change the intake manifold and with everything do some internal work as well if you truly want to see some gains
mrcell24
May 19, 2015 10:02 AM
nongv
Apr 2, 2002 05:34 PM
Cross
16
Feb 28, 2002 10:34 PM
SugarRay
Bolt-on Engine Performance
19
Jan 8, 2002 02:55 PM
MooCoW
Nov 15, 2001 10:58 AM
