need diy on hid
Old May 26, 2003
IllusiveImports's Avatar
IllusiveImports is an unknown quantity at this point
need diy on hid
can someone please give me a diy on catz hid on tyc's i have searched but found nothing but look at the directions that come with it. i want to find a diy before i buy it though
thanks
Old May 26, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
All the instructions should come with HID when you buy them.. It's all Plug-n-play
Old May 26, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
errr. find a place to install the boxes... wire them to the headlights... ummm turn lights on ?? try using the directions that come with the lights... I think thats why they give you them. lol not tryin to flame... just being realistic.
Old May 26, 2003
how about for tyc someone told me there are metal clamps that connect to the harness but what about the high beams on the tyc ???
Old May 26, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
ur out of luck .. the high beams will be normal stock light... thats a sacrifice ur gonna have to make.. some HID kits have High and low in one bulb but they cost more... what do you need high beams ne way with HID's ??? they are bright enough.
Old May 27, 2003
thats not what i meant sorry for the cunfusion. i meant i want a low beam only hid system for the tyc projector and i know that it just has metal clamps that connect to the wire harness so do i just need to run one from the high beam to the harness as well since it won't be able to be pluged in due to the clamps for the low beam
Old May 28, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
nah just disconnect the clamps to the high beam.. reason why tyc has that is cause we have dual filiment bulbs in our OEM lights... and when u turn on the high beams .. a different wattage gets sent to the lights and turns on the HIGHs... I dont have tyc projectors but im assuming theres some kind of built in relay that detects the wattage change and switches from the low projector to the HIGH beam... just disconnect the clamps .. and connect the HID as normal to the low beams... your basically just not allowing power to goto the high beam ... making it useles since your going to HID... does that help ?
Old Jun 11, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
I have an H1 hid kit in my TYC's. It's made by Xenon. Very very bright and I suggest you get this kit. I don't know how the CATZ system is set up but I can give a DIY for the Xenon kit that I have. I actually had to modify the metal bulb housing and the rubber water resistant cap that covers the housing.
UltraHDGames
Jun 8, 2016 05:16 PM
speedlever
Sep 24, 2015 07:18 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
