just installed my neuspeed F U bar
Old May 22, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
i finally installed it today...it took a while, the bar didnt line up correctly, so i tried jakcing up the drivers side, it didnt help, it was the same(i even loosened the third bolt) so i was ready to give up...i lowered the car back down, then tried to place the bar on the drivers side first, then force it on the passenger side, it worked. i torqued it to 33 ft lbs, does anybody know how much u torque that third bolt that i had to loosen for jacking up the drivers side, i did it to about 33 ft/lbs anyway. well its kinda wet out so i didnt really test it out fully. the car still does lean like crazy when i turn, i know its only a strut bar, but ill test it out more when it dries up outside. i really didnt notice better steering as much as i thought i would
im gonan install my x brace next week, so hopefully ill notice more of a change
Old May 22, 2003
Weaponx12o's Avatar
why'd you have to jack up the car? mine just popped in place, err kinda had to force it at times. but it fit nonetheless. every bolt for that should be torqued 33 ft. lbs. show pics of your x-brace install.
Old May 22, 2003
i tried jacking it up cause it says to in the instructions if it doesnt fit into place. i thought maybe they sent me the bar for the wrong car or something, it was impossible to fit it on the drivers side after puttin it on the passenger side first, so i tried putting it on the drivers side first, then the passenger, then it fit.
Old May 22, 2003
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
i jacked my car up when i put mine on. wasnt a big deal just moved the strut around until the bolts lined up with the strut bar.
Old May 22, 2003
Pharoh's Avatar
Bobaganoosh!
I had to jack up my ride. I pitty the fool that ever has to take off my bar...there's alot of pressure on it.
Old May 23, 2003
Weaponx12o's Avatar
you have to try to put it in at the same time. it's harder to install if you do one side at a time.
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
fordover
Jul 11, 2015 09:10 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
