What do I use to cut springs?
Old May 19, 2003
DXPOWER's Avatar
DXPOWER is an unknown quantity at this point
I read through a few old posts and people mention using a dremel or other low heat methods to cut springs. What other low heat methods are there? I don't think I want to buy a dremel unless I have to.
Old May 19, 2003
Jodster's Avatar
Post Whore General
Are you cutting your stock springs? Wow. Well when you hate the bounce you will be getting and want to get another set of stock springs e-mail me. I have a set left over.
Old May 19, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
sissors!!! NO DONT CUT UR SPRINGS buy new ones
Old May 19, 2003
DXPOWER's Avatar
I sould have elaborated more, sorry. I am going to cut a DEAD coil off the two rear neuspeed sport springs on my car. When I bought them I was sent the sedan springs and I had them installed not knowing there was a difference between the coupe and sedan springs. The *** end of my car is too high, and many people on this site have had the same problem with neuspeed sports and cut their springs with success. I just don't know what to use to do it.
Old May 19, 2003
Jodster's Avatar
Post Whore General
oh, got ya. Well I would say to use a dremel tool. That way you can make it as accurate as possible. You don't want them to be uneven.
Old May 19, 2003
ok well go to a welding shop and have them cut it using their arcs
Old May 20, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Call Neuspeed and ask for them to replace them with the correct ones.
Old May 22, 2003
Weaponx12o's Avatar
thats the best way to go, it's better than potentially damaging the ones you have now. why dont you try to return it for the right set?
Old May 22, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Neuspeed cold rolls the coils... heating them up like that would change the material properties and probably screw them up severely. If you're going to cut them, do it with something relatively cold... or call neuspeed and get them replaced.
Old May 22, 2003
VNlilMAN's Avatar
The Standard One
ya neuspeed "replaced" mine for free. but then their headquarters was only an hour away so i was able to. there isnt anything wrong with cutting the dead coil. just make sure you cut 1 whole coil and not half or anything. try using a hand saw? you might be able to rent a dremel at home depot.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Mc7602
Sep 17, 2015 02:01 PM
