neuspeed front strut bar Q
Old May 17, 2003
R3DL1N3's Avatar
when installing a neuspeed front strut bar do u have to re-arrange anything to get it to fit or does it mount perfectly??
Old May 17, 2003
civicvtec1ps's Avatar
Search and Learn
i didnt have to do anything to put neuspeed front strut bar.
Old May 18, 2003
R3DL1N3's Avatar
kthx
Old May 18, 2003
hassoomi's Avatar
well, that's not true for everyone. i have no idea why, but i had to do some jacking up to get mine to fit. i mean, i expected that, cuz it's in the instructions, so it's no big deal......but don't be surprised if it won't go on perfectly
Old May 18, 2003
Weaponx12o's Avatar
it fit mine fine, you just have to slightly bend it a bit to fit and push down all the way to make sure it is on properly
Old May 18, 2003
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
On 5 spd cars, you may have to move the clutch resevoir to a location lower. There is a bolt already there you can use. Easy to do, just a little awkward and tight in there. Some people just bent the bracket, I didn't like that idea.
Some cars may need to be lifted on 1 side (neuspeed states which side) for the bar to fit. I had no problem.
I had one on my '94 civic and on my em2. Would not choose any other brand!!
Hope this clears it up!!
Old May 18, 2003
synikal's Avatar
synikal is an unknown quantity at this point
if its a 2001 civic, I think it the reservoir has to be moved. if its a 2002 or higher, like me, you dont have to move "adjust" the reservoir, just bend it out of the way a lil.
Old May 19, 2003
robbclark1's Avatar
Retired suspension supermod.
mine is a 2001 and i just moved it out of the way. I didn't have to jack up my car, though some other did. Mine fit right in.
Old May 19, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Bingo... thats exactly what the directions say. You might have to jack the car slightly to get the bar to drop on the bolts, but just enough to get the wheels off the ground. It shouldn't take more than 20 minutes to do it... and make sure you torque the bolts down to 33... don't hand tighten them unless you're sure you can get to 33 or more. I hand did them and thought it was tight enough, and then torqued it another 10 lbs before I hit 33... and it makes a difference.
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
andylao
Nov 4, 2001 01:19 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
