when you install your body kit..
Old May 17, 2003
R3DL1N3's Avatar
do you usually paint the pieces before you install them or vice versa?
Old May 17, 2003
ImPulse's Avatar
i heard you put the kit on the car to make sure it fits correctly...
Then if it does fit correctly
take it off, and paint it, then put it back on
Old May 18, 2003
Bartkat's Avatar
Yep. Much better to paint it off the car.
Old May 18, 2003
nightkids1's Avatar
Initial D!!!!
yeah, dont be ricey and put the kit on not pianted. mjust make sure it fits before you paint it.
Old May 18, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
you all might not like to ride with an unpainted kit but its good to for a few weeks or so. A few reasons come to my mind. 1-its lower(usually) than your OEM bumper and nothign sucks worse then getting it put on and you accidently hit a drive way and have to repair it and repaint it. Get used to driving it before you paint it cause its alot cheaper to repair a bumper than it is to repair AND repaint. 2- most kits(especially fiberglass) tend not to fit great. I notices where the bumper goes around the grill and meets the hood is always a good place for vibration and once you paint it the paint will start to chip. I took a sharpie and colored the tops of this peice black and about 2 days later the marker was gone cause the vibration made the bumper rub againt the hood and would have taken off the paint. You cant tell its going to rub until it does. Youd be suprised how much a bumper actually shakes and moves on the road.i still didnt sand that part down enough and have a little chip where it rubs againt the hood.a fre other spots are like that as well. SOrry for the lenghtly reply
Old May 18, 2003
importz2k1's Avatar
That's good advise David !!!!
Thanks for the input.
Old May 18, 2003
Cocky's Avatar
Cocky guys kick ass!
what do ya do if it doesn't fit exactly? I ordered a G5 kit a few weeks ago, and it should be in anytime, so any help with installing it will be great.
Old May 18, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
body shop with have to modify it.
Old May 19, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
The shop that painted my kaminari kit said they put it on the car to see if they had to modify anything then they took it off and preped and painted everything.
Old May 20, 2003
TOOLOWCIVIC's Avatar
Hey cocky the g5 kit from wings west should fit just fine. No problems with that kit.
Misfit2613
Jul 30, 2015 09:49 AM
Jul 12, 2015 11:54 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
