eibach 1.4 inch drop, camber needed?
Old May 12, 2003
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
i just installed the 1.4 inch drop eibach springs, its a nice ride, realy nice after i got it realigned, i heard that i would not need a camber kit unless i went lower than a 1.5 inch drop, is this tru? has anyone else installed the sportline springs, if so how did it turn out for you?
Old May 12, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
just to let ya know i have newspeed race springs with 18's and no wheel gap and i do not need a camber kit. don't worry about it.
Old May 13, 2003
flotsamm's Avatar
Re: eibach 1.4 inch drop, camber needed?
So all they aligned was the toe I assume since they cant really align the camber setting without kits installed. I have the Eibach Sportlines(sames as yours I assume) and my rear tires were cambered in slightly so I installed a SPC kit.
Old May 13, 2003
SODJAZERO's Avatar
what is a spc kit?
Old May 14, 2003
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
I have the eibach pro-kit (1" drop) & my front camber is fine.. but my rear was slightly off spec at around -1.8 (i think) but anyhow I can definately see the wear on the rear tire, its not a lot but its still there. so my suggestion is you may need at least a rear camber kit
SPC makes camber kits for our cars front & rear http://www.spcperformance.com/
and you can buy here for cheap http://www.danscreations.com/spc/camberkits.html
& thier may be a group buy on the SPC still?
Old May 14, 2003
reflekt's Avatar
reflekt is an unknown quantity at this point
how much does it cost to install the camber kit?
how much for just the rear camber kit installed.
and how much for both the front and rear.
is this easy to install by urself? alright, thanx.
Old May 15, 2003
flotsamm's Avatar
Both the front and rear kits are easy to install with simple hand tools. Just make sure that you take it in for an alignment soon after.
izdman
May 19, 2015 03:43 PM
Myredjonda
Apr 14, 2015 07:00 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
katya
Nov 2, 2001 08:22 PM
ImmortalEX
Oct 31, 2001 10:00 PM
