Altezza grill question
Hi guys, I have just installed my altezza grill. Since the stock radiator doesn't fit (mine is a coupe), so there is a gap b/w the hood and the grill(I can put a finger in it). Does this do any bad for my car??? And is there anyway to cover that gap???
Originally posted by Majarvis
Do you mean even with the sedan radiator cover installed in place of the coupe cover, there will still be a gap left?
No no, but with the coupe radiator cover there is a gap when you install the grill, since it's meant to be put on a sedan's radiator cover, but I'm trying to find out if he means even with the sedan cover installed on the coupe if there is still a gap between the hood and the grill (confusing I know)
I have a coupe....with altezza grill, and sedan radiator cover. The cover cost me 16 bucks at my local honda dealer. If you stand back from the car, it looks like there might be a small gap. But nothing that you could put your finger through. The sedan radiator cover hooks up perfectly with the grill. Its pretty cool.
Oh ok, so you have the sedan radiator cover and a grill on a coupe, ok cool, you'll be the victim/tester and let me know
j/k
j/k
I'm confused. I mean, isn't there a gap between the top of the stock grill (2dr/4dr) and the hood? I would think it's normal if there's a gap between the Altezza grill and the hood. Right? Jus askin.
Man, I think I'm the only one that paid the most for the 4dr radiator cover... $19. Oh well.
I believe the gap would still be there even with the 4dr radiator cover on. You would have to add something else to the top of the grill to close the gap.
BTW, you're talking about the gap between the top of the Altezza grill and the front part of the hood, right? And not the gap above the radiator, right? I just want to make that clear.
This is the best picture I know of that shows the gap. I hope I don't get in trouble for using this as an example, but this is DC5@EM2's car pictured in Hondawerx.com. The last picture shows the Altezza grill and the gap... I think. If that's what you're talking about, then yes, I believe there will still be that gap even with the sedan radiator cover.
Guys!!! Look at your factory grill!!! There's a gap with it too, but you don't notice it as much because of the H in the middle and the crodd bar going accross...How do you think you get to your hood latch?? ...You guess't it.....the gap!!!
that gap isnt really a gap. it is only there because the altezza grill sits further back than the stock grill. it is recessed, so you see a "gap". what color is your car? it is alot less noticeable on NBP cars. check out my ride for a close up of the grill.
Don't worry to much about the gap. Afther a few weeks of installing mine I didn't bother me at all. Now I think it looks kind of cool.
Just give it time and you'll get use to it.
martinsmartin
Aug 15, 2015 07:34 PM
civic98?
Aug 13, 2015 01:32 AM
