Wet Filter Type vs Dry Filter Type...
Old May 8, 2003
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
Question Wet Filter Type vs Dry Filter Type...
Ok, from what I know and understand, the wet filter type is one that is oiled, like the ones that come on AEM products, whereas the dry type is the kind that A'PEXi makes. What I am wondering is, since A'PEXi doesn't oil theirs, does that mean it filters the air as efficiently as the other wet type filters, or is it just for the sole purpose of reducing the restriction of air? Because I was just wondering is if it's just the fact that they allow more air through, could you infact oil the A'PEXi dry type filter? Or would that reduce the efficiency of it, and mess it up somehow? Or are they designed to filter efficiently enough without oil? Thanks.
Old May 8, 2003
Majarvis's Avatar
Also, I know that the AEM SRI piping has a 3" diameter, so will the A'PEXi universal filter fit that?
Old May 8, 2003
Connie's Avatar
I would imagine they would make one to fit it cause it is called a Universal Filter...
Old May 8, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
just depends on the filter size, might need a adapter
Old May 8, 2003
PunkingCivic's Avatar
I need TP for my bunghole
It really depends on the material fo the filter element its self.
Dry filters are commonly a sponge / foamy material.
Wet filers like K&N AEM filter is a cotton based filter element that needs to have the oil to be reusable this way the dirt and stuff sticks to it for better cleaning. I think.
And then there are stainless steel filters.
As for universal filter thay can be used but just make sure you are getting the proper size universal filter.
Old May 8, 2003
Majarvis's Avatar
Ok well here is what I'm talking about just to clarify. APEXI POWER INTAKE FILTER
Note: May Require Use of Adapter
What kind of adpater would I need?
3-Point Sound Adjustment
It says that it will only work with an A'PEXi intake system, but it says universal
It also says it's 80mm, so that should fit a 3" pipe correct?
Old May 8, 2003
It shoud fit 80 milimeters = 3.149606 inches
Well it seems like it would be pretty cool.
I'm no expert though.
sounds like a turbo filter.
Cool that it is sound adjustable though.
Old May 8, 2003
Majarvis's Avatar
What does it mean by sound adjustable though?
Old May 8, 2003
I looked that apex i site and it looks like an adapter is need look at the pic
http://www.apexi-usa.com/intake_powerintake.asp
As for the adjustable I don't know call or email one of the two companies.\This is quite a filter dilema.
Old May 8, 2003
Majarvis's Avatar
Hmmm. I don't know how on earth that would go on then, and I haven't seen an adapter on any site mentioned for that. I think I'll just forget about getting that unless someone has any more info on it.
Old May 8, 2003
Yah I would try another filter
the application chart shows the follwing
Honda/Acura
508-H001 Civic 92-95
508-H002 Prelude 92-96
508-H003 Accord 94-97 (4 cyl.)
508-H004 Integra 94-99 including Type-R
508-H005 Civic 96-99 Coupe EX / Si
508-H005 CRV 97-00
here is the faq setion at K&N
Old May 8, 2003
Majarvis's Avatar
Yeah I guess I'll just stick with the one that comes on the AEM SRI.
SimpleUser
Apr 24, 2021 02:54 AM
brags
46
Jan 7, 2016 09:39 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
CivicsClass101
Jul 9, 2015 11:14 AM
