Help with Painting Trim Pieces
Old May 6, 2003
abmerop18's Avatar
Jam out with your clam out.
i am having trouble with painting my center trim piece that surrounds the cd player. i took apart the whole center console and removed all the switches and controls and the cigarrete lighter box area. i cant find the two screws that hold the console in though. i know that when you remove the center console there are two screws up front at the bottom attached to a metal pillar, but they didn;t do anything. can someone please post a picture of where these screws are. thanks for the help.
Old May 6, 2003
XxSoVeReiGNxX's Avatar
are you talking about these screws? I don't undersstand if you have already taken them out or if you just can't find them.
That metal piece is actually a part of the frame of the dashboard.
FlyRice pointed out that they are not present in his 2003 model. However, they are there in 2002 models. I have 2001 and they're there.
Old May 6, 2003
You see #14? That's the other piece of metal that's bolted onto the one above. #14 is attached to the head unit, so you will need to take the screws out to get the head unit off the dash. Considering if it's even there.
Old May 6, 2003
abmerop18's Avatar
yyes, i cannot find that. where is it? i think when i look up all i see is one screw in that area. i have a 2002 civic. is it like that in the 2002? and as for the #14 in the picture, where is that located?
Old May 6, 2003
doubledeuce2k2's Avatar
i couldn't see those either when i took them out. mine were kinda farther back than they looked in the picture. i just stuck a socket back there (8 or 10 mm, can't remember) and felt around the top piece till i got them.
but believe me, they're there. mine is a 2002
Old May 6, 2003
#14 is behind that metal strip with the screws on it in the first pic. #14 is what's bolted to that strip in the first pic (imagine two slices of bread on eachother, with two toothpicks going through both of them).
And no, the screws (and that metal strip) aren't very visible. That first picture was taken from directly underneath the dashboard, making it look like that bolts are easily accessible. They are actually far up and hard to reach. The single screw you saw was probably the correct one. The other one is hidden more under the plastic lower dashboard.
Old May 6, 2003
abmerop18's Avatar
alright i guess i can take another look at it tomorrow. did any of you guys add a clearcoat when you finished? and if so, what kind?
Old May 6, 2003
RoadRunner's Avatar
i just got some clear coat from home depot. i didn't really look for anything in particular, clearcoat is clearcoat to me. do about 3 layers and be sure to have plenty of time inbetween layers
Old May 7, 2003
Salt's Avatar
Salt is an unknown quantity at this point
Actually, can someone teach me how to pull out the cigaritte box area??? I use all my strength and still can't pull it out....(i follow the DIY instruction from this site)
Old May 7, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
Just start at one side, and push a small screwdriver in thc crack, pry it out a little bit untill you can get your hand on it then just pull straight out. There are 2 clips on te top, and 2 more on the little side pieces. Just make sure your pulling straight out on it or it might break one of the clips
Old May 7, 2003
abmerop18's Avatar
alright, im still having trouble with my. my 2002 civic coupe is being really gay. i took a picture of the only screw in there and it is a frickin square!!?? wtf?? how am i supposed to unscrew that? i posted a picture. please help.
Old May 7, 2003
khmaitiger's Avatar
khmaitiger is an unknown quantity at this point
get one of those gator wrench things that can like work with ne size of nut its like 15 dollors.. would that work guys?
Old May 8, 2003
abmerop18's Avatar
nevermind i figured ou the problem. i took the car up to honda and they said that when they installed my CD plyer they took out the bracket with the screws in it to fit the CD player. all i had to do was to pop out the center piece. thanks for the help though.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
carid
Sep 28, 2015 10:13 AM
speedlever
Sep 24, 2015 07:18 PM
