Wheel Size
Old May 6, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
Wheel Size
Ok, I've decided on two wheels the MOMO Quasar II's or the Konig Blatant Opal. I'm debaiting if I want 17's or 18's. If the wheel is 18 x 7.5 what size tire should I get and will it rub?
Old May 6, 2003
obtix's Avatar
The Konigs
Old May 6, 2003
obtix's Avatar
The Momos
Old May 6, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
215 or 225 / 40-18
225 should flush, 215 tires should angle a lil bit.
Old May 6, 2003
Master
i know a few people with 225 width and lowered no more than 2 inches, no rubbing.
Old May 6, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
The widest I'd get is a 215. That width is flush with the wheelwell. If you get a 225 it will stick out a little bit. I'd also get the 17's instead of the 18's. The 18's will affect your performance, and since we don't have very fast cars, I'd get the 17's.
Old May 6, 2003
obtix's Avatar
CivicEnvy.. I know the 18 will slow my car down.. but i'm doing 8 pounds of boost from a t3 turbo this summer.
Old May 6, 2003
Master
wont' slow u down unless it weighs less. it's all about the weight.
Old May 6, 2003
No, if the diameter is larger than the stock tire then your car will have to work much harder to get the wheels moving.
Old May 6, 2003
Master
well, if he goes with 17x7 or 17x7.5 he probably will use 205 or 215 width. The diameter has some effect, but if the wheels are 5lb lighter than stock one, then how is that gonna slow it down? Unless he runs with 225, which might be too wide and has more contact with the ground, then it will slow the car down....by milli second
Old May 7, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
That really depends if the wheel is forged or caster. If it's caster, sure. If it's forged, then it's not so bad.
Old May 7, 2003
All Eyes On Z
WTF?
Old May 7, 2003
All Eyes On Z
I also want to add that with forged rims, the mass weight of the center of the rim is lighter... thus allowing less inertia/energy to rotate that wheel.
Old May 7, 2003
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Well I have 17" rims with 215/45 and I wish I had gone with the 18" since I don't use them for performance as much as I though I would. But I would say go with the 2nd ones. On 18" I would go 215/40 or 225/40 no way I would do 215/35.
Old May 7, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
MOMOs are heavy as FVCK. I'm talking like 25 or 30 lbs. They're beefy. If you have plans of going fast, get 17's. If you just want to look good, then 18s. I have 215/45 and the tires sit flush with the edge of the fenders. 17's also help if the roads suck.... but I'd choose the Konigs eitherway.
Old May 7, 2003
All Eyes On Z
Old May 8, 2003
Jap-Euro Fusion
If the given choices are 17 or 18, would you choose the 18? I don't think so. Sure, if you really wanted to go fast, get 15's... but thats not a choice here is it?
Old May 8, 2003
All Eyes On Z
Either way if THAT'S the choice one must not care enough about going fast over making their car look good. Bottom line, 17s kill performance and don't have "speed" in mind since you'll go slower that stock no matter what.
IMO, concerning performance I think it would make more sense to say, if you want to go slow, get 17s. If you want to go even slower, get 18s.
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
