problem with radio
Old Apr 29, 2003
rowin2k's Avatar
rowin2k is an unknown quantity at this point
problem with radio
The problem is..... radio wont turn on....
i think i blew a fuse somewhere, i checked the fuse panel underneath the steering column and it wasnt blown but i replaced it anyways. Any ideas what it could be?? I was connecting the remote wire to my amp and i hit the ground and it sparked.... of course..... and then my radio shut off .......and now it wont turn back on...
Old Apr 29, 2003
Check all your fuses. If it sparked, you blew a fuse. You may be able to look up the right one in the manual, otherwise you'll have to check them all.
Old Apr 29, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
I believe the fuse for all of that stuff is under the hood.. I think its a red one (if that helps). I've blown that one a ton of times so I think you should check there and then let us know if thats not the problem.
Old Apr 30, 2003
rowin2k's Avatar
i am checking the fuses right now.. i pulled them all from under the steering column... let me check under the hood
Old Apr 30, 2003
rowin2k's Avatar
definately was a fuse.. and thanx guys i appreciate it... oh yea... it was the red one!!!
Old Apr 17, 2005
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
The same thing just happened to me I almost cried, and thankfully I wasnt too lazy to search for this old thread and it solved my problem it was the back up reinstallation fuse!!!!!!!!!!!!!!!
paddystrang
May 18, 2015 09:56 PM
ywgflyer
May 15, 2015 05:05 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
