problem with radio
problem with radio
The problem is..... radio wont turn on....
i think i blew a fuse somewhere, i checked the fuse panel underneath the steering column and it wasnt blown but i replaced it anyways. Any ideas what it could be?? I was connecting the remote wire to my amp and i hit the ground and it sparked.... of course..... and then my radio shut off .......and now it wont turn back on...
Check all your fuses. If it sparked, you blew a fuse. You may be able to look up the right one in the manual, otherwise you'll have to check them all.
I believe the fuse for all of that stuff is under the hood.. I think its a red one (if that helps). I've blown that one a ton of times so I think you should check there and then let us know if thats not the problem.
The same thing just happened to me I almost cried, and thankfully I wasnt too lazy to search for this old thread and it solved my problem it was the back up reinstallation fuse!!!!!!!!!!!!!!!
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
