goldline spring rates
Old Apr 26, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
anyone know what the spring rates are for the goldline springs for coupes?? it didnt say on the box.
Old Apr 28, 2003
VNlilMAN's Avatar
The Standard One
all i know is its very soft...
goldline posted it a LONG time ago..
something like 300lbs maybe..
Old Apr 28, 2003
can u please elaborate what the spring rate actually is? my friend was askin me what the ratings were and i had no clue. what does the 300lbs rating mean? good bad?
Old Apr 29, 2003
VNlilMAN's Avatar
The Standard One
theres no good badd.. but there is soft vs stiff...
with the basics...
-there are two type of springs.. linear and progressive.. linear has a constant spring rate while progressive springs dont. just keep that in mind...
-spring rates is how much weight it takes to compress the spring 1".
-so you have a linear spring thats 300lbs, put 300lbs on top of it and it compresses 1". put 600lbs and it compresses 2". 900lb - 3", etc...
-BUT on a progressive, its not constant. the springs get stiffer as it gets compressed more. so with 300lbs it might compress 1" but with 900lbs it might only compress 2" rather then 3". thats why its not easy to determine the spring rate on progressive springs.
-most lowering springs are progressive.
-keep in mind we have 4 springs on the car so 300lbs in the trunk doesnt mean the car lowers 1". it also doesnt mean the car lowers 1"/4 springs = .25" cause remember theres weight distribution
Old Apr 30, 2003
Roy's Avatar
Roy
Roy is an unknown quantity at this point
if i remember correctly, it's 360lb. front, 420lb. rear. It's that or close to that rate.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
