headlight clearing question? need answer asap
I Am The Chosen One
ok before i seal these suja's up and put on the ride i have 1 question. there is a peice inside the headlight that surronds the bulb, do i take that out or do i leave it in place, i think it is called a difuser? i'm sealing them up on sat so the sooner i get an answer the better. all the help is appreciated.
Definately DO NOT REMOVE THE DIFFUSER, it was engineered for a reason, many dumbasses removed them and they claim it to be brighter but technically the light is scattered apart, the diffuser is used to focus the beam. Its like the Eurolites (25$ a pair), they look brighter than other hyper white lights (like those middle quality ones) because Eurolites are scattered while many better quality bulbs focus its beam.
I want to get mine cleared too
Maybe we should all get a bunch of us together and profurious can show us / help us do it
p.s. WTF is with those clips all over the car (holding plastic/rubber parts off), when I was wiring my sidemarkers, I broke a couple. I can't get them off without breaking them! The instruction manual says take a flat screwdriver to pull it up, but that never works and they break. grrr
Instead of prying with a flat screwdriver try turning it. It put the flat screwdriver in the lot at the side and turn clockwise, instead of prying.
The actual clearing of the lights doesn't worry me too much, i am more concered about the bumper removal and re installation.
Peace
Peace
I Am The Chosen One
just finished install 10 min's ago, the easiest part is removing the bumper, its a lot easier than doin the headlights. jer i'll get some pics on monday.
?? how long did it took u to do all that??
yes the headlights is the hardest part, hehe i have to put mine in that oven! if i have found out earlyer then clearing headlight would take half an hour
If you guys are worried about removing the whole bumper just bend pull it off you can tilt it forward and have enough room to take out the headlights. It's the same process as taking off the bottom except you don't take off the clips at the bottom which are a pain to get off.
usajags84
15
Aug 19, 2015 03:12 AM
greencivic805
Nov 16, 2001 10:36 PM
