headlight clearing question? need answer asap
Old Apr 25, 2003
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
ok before i seal these suja's up and put on the ride i have 1 question. there is a peice inside the headlight that surronds the bulb, do i take that out or do i leave it in place, i think it is called a difuser? i'm sealing them up on sat so the sooner i get an answer the better. all the help is appreciated.
Old Apr 25, 2003
dbzcivic's Avatar
dbzcivic is an unknown quantity at this point
i didn't take anything out other than my light bulb.....
so i would say leave it in.
Old Apr 25, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
The only thing you take out from the setup is the yellow piece... DO NOT TAKE OUT THAT PIECE THAT COVERS THE MAIN HEAD LIGHT BULB!!!
Old Apr 25, 2003
profurious's Avatar
I Am The Chosen One
thank you much obliged
Old Apr 25, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
Definately DO NOT REMOVE THE DIFFUSER, it was engineered for a reason, many dumbasses removed them and they claim it to be brighter but technically the light is scattered apart, the diffuser is used to focus the beam. Its like the Eurolites (25$ a pair), they look brighter than other hyper white lights (like those middle quality ones) because Eurolites are scattered while many better quality bulbs focus its beam.
Old Apr 25, 2003
Blkcivic's Avatar
what the hell are u guys talking about! i've cleared my lights but never came across to this
Old Apr 25, 2003
oldskool's Avatar
oldskool is an unknown quantity at this point
ummmm,w hy didnt u tell me u were clearing them, I want mine does as well!!
Old Apr 25, 2003
jer2k's Avatar
jer2k is an unknown quantity at this point
Don't worry, he's doing everybody's from the Region. RIght?
Peace
Old Apr 26, 2003
oldskool's Avatar
he btter cuz i want mine cleared....or maybe just gonna get new headlights
Old Apr 26, 2003
jongreenway's Avatar
jongreenway is an unknown quantity at this point
I want to get mine cleared too Maybe we should all get a bunch of us together and profurious can show us / help us do it
p.s. WTF is with those clips all over the car (holding plastic/rubber parts off), when I was wiring my sidemarkers, I broke a couple. I can't get them off without breaking them! The instruction manual says take a flat screwdriver to pull it up, but that never works and they break. grrr
Old Apr 26, 2003
jer2k's Avatar
Instead of prying with a flat screwdriver try turning it. It put the flat screwdriver in the lot at the side and turn clockwise, instead of prying.
The actual clearing of the lights doesn't worry me too much, i am more concered about the bumper removal and re installation.
Peace
Old Apr 27, 2003
profurious's Avatar
I Am The Chosen One
just finished install 10 min's ago, the easiest part is removing the bumper, its a lot easier than doin the headlights. jer i'll get some pics on monday.
Old Apr 27, 2003
Blkcivic's Avatar
?? how long did it took u to do all that??
yes the headlights is the hardest part, hehe i have to put mine in that oven! if i have found out earlyer then clearing headlight would take half an hour
Old Apr 27, 2003
oldskool's Avatar
ummm i tihnk profurious needs to do mine.......maybe you can ditch the fiance for a night and clear mine.
Old Apr 27, 2003
XxJDMCivicxX's Avatar
If you guys are worried about removing the whole bumper just bend pull it off you can tilt it forward and have enough room to take out the headlights. It's the same process as taking off the bottom except you don't take off the clips at the bottom which are a pain to get off.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
usajags84
15
Aug 19, 2015 03:12 AM
SWEETRIDE
Nov 27, 2001 05:52 PM
greencivic805
Nov 16, 2001 10:36 PM
